PC skipping and freezing, cpu temp jumps 5-10 degrees when it happens, how do i fix this problem
Mar 18, 2018
11
Hi so about 2 weeks ago my pc randomly started freezing at times and skipping for a solid 3-5 seconds. It can be very annoying while playing games as it has cause me to die a ton of times. I decided to monitor my CPU temps while playing or being idle and waiting for the skips. Just as guessed everytime my pc skips my CPU temp jumps about 7-10 or more degrees in those 3-5 seconds the skipping occures. I just got a new CPU cooler and the temps arent overheating at all just jumping up when the skipping happens and I dont know what to do at all. If anyone can help that would be great!
CPU is an Intel 15 8600k and GPU is a GTX 1050ti. And yes my screen pauses and jumps to a few moments later
neither the CPU or GPU is maxed out while playing. When the skip happens my temp surges up about 5-10 degrees though. The temp is not at an overheating temp but it has a huge spike in temp when the skip occurs
