Question PC starts, no image og screen. VGA led light up og motherboard.
Apr 26, 2020
The pc is about two years old. It uses a gtx 1060 6gb. Recently it started booting up but no image showed up on the screen. The screen does turn on though and the VGA error LED lights up on the motherboard. I have tried using the second PCI slot on the PC with no luck, and tried using a different card (gtx 970). Sometimes it would work just to take the graphics card out and put it back in, but that doesent seem to be the case anymore.
Does anyone know what the issue might be or a fix for it?
Thank you
What's the make and Model number of your Motherboard ? Does it have support for integrated graphics/iGPU ?
Try to clear/reset all the CMOS/BIOS settings to default, if need be, and then try installing the GPU.
The motherboard is an MSI B350 Tomahawk. I think it has support for integrated graphics, but my processor (ryzen 5 1600) doesnt... I managed to make i boot once. But that has worked in the past. I pulled the CMOS battery, and it looks like its working, but i wont really know for sure untill i try booting it a couple of times.
Thank you very much for your suggestion 😀
