Question PC sudden loss of power, failure to boot and fan kept turning on and off ?
Mar 11, 2025
5
I was using my PC like normal when suddenly it lost power. I went to go and turn it back on but to my surprised it failed to boot, with symptoms:
-Fan speeding to full speed then turned off( repeated indefinitely unless cut from power source)
- Sudden flash of CPU LED on the motherboard (along side with the fan)
-Case’s power button unresponsive
Here is what I’ve tried to diagnose the problem:
-Re-slot RAM
-Re-slot SSDs
-Remove all USB peripherals
-Paperclip test the PSU
-Check if there is any blown capacitors
-Re-slot GPU*
*After I removed the GPU (which at the time I was using with a PCIE cable extension), the PC booted, I tried to reinstall it and my PC was happily running again.
Unfortunately after 2 hours it all happened again, I suspect that the PCIE cable was at fault so I removed it and my PC was up and running again…for 5 minutes.
My PC is now in a crisis of eternal power cycling and I ran out of ideas what might be wrong with it.
Please help.
Hardware:
I7-12700F
RTX 3060 COLORFUL 12GB
GIGABYTE P650B - 650W - 80 Plus Bronze
Samsung 980 NVMe 1TB
16GB Corsair Vengance DDR4
Mainboard ASUS TUF GAMING B660M-PLUS D4
I figured out the problem. It wasn’t the PSU but the motherboard, when I pressed against the second PCIe slot (just below the 16x) the computer booted, and turned off quickly as soon as I stopped pressing against it. Are there anyway to fix it or the motherboard is on its way out?
Is the motherboard grounded?
