PC Temperature Monitoring
faridc
70
Hello,
I have recently upgraded my PC case to improve airflow.
I went from a generic store bought ASUS CM 6730 desktop original mid tower to a Fractal ARC Mini R2.
I was able to move all the components and added a couple SSD's successfully.
My mobo is an ASUS P8H61-M Pro (original one that came with the generic desktop).
I have recently downloaded a temp monitoring software: Open Hardware Monitor (http://openhardwaremonitor.org/) and been keeping an eye at the temps in different components, it even gives me the temps of my HDD and SSD's.
These are the readings I am getting and was wondering whether they are OK:
+- ASUS CM6330_CM6630_CM6730_CM6830_M11AA (/mainboard)
| +- Nuvoton NCT6776F (/lpc/nct6776f)
| | +- CPU Core : 29.5 53.5 (/lpc/nct6776f/temperature/0)
| | +- Temperature #1 : 86 87.5 (/lpc/nct6776f/temperature/1)
| | +- Temperature #2 : 94.5 98.5 (/lpc/nct6776f/temperature/2)
| | +- Temperature #3 : 31 33 (/lpc/nct6776f/temperature/3)
+- Intel Core i7-3770 (/intelcpu/0)
| +- CPU Core #1 : 27 54 (/intelcpu/0/temperature/0)
| +- CPU Core #2 : 27 49 (/intelcpu/0/temperature/1)
| +- CPU Core #3 : 27 48 (/intelcpu/0/temperature/2)
| +- CPU Core #4 : 27 52 (/intelcpu/0/temperature/3)
| +- CPU Package : 27 54 (/intelcpu/0/temperature/4)
+- NVIDIA GeForce GT 630 (/nvidiagpu/0)
| +- GPU Core : 28 52 (/nvidiagpu/0/temperature/0)
| | +- Fan #1 : 974 1223 (/lpc/nct6776f/fan/0) (rear Fan)
| | +- Fan #2 : 1530 1783 (/lpc/nct6776f/fan/1) (CPU heat sink-Fan)
The Fractal Case came with 3 fans: rear, top and front.
I connected the rear fan to the mobo, the top and front fan to the PSU through the case fan control switch (3 positions: 5v, 7v and 12v). They run at constant speed depending on the switch voltage.
Are these temps OK?
all the temp are good this auxiliary must be the same thing i have with another name that show -128 c on my system , stay around and let see if someone else use the same board and could confirm your readings .
They look quite similar.
The one I was worried about is this one:
| | +- Temperature #2 : min: 94.5 - max: 98.5 (/lpc/nct6776f/temperature/2)
These are degrees Celsius. They seem kinda high!
The readings from HWInfo show:
Nuvoton NCT6776F
motherboard 31.0 C
auxiliary 95.0 C
systin1 31.0 C
systin2 31.0 C
systin3 31.0 C
CPU 29.0 C
is that reading of 95 C normal?
OK, thanks...
My Motherboard is an ASUS P8H61-M Pro.
I'm quite worried about my Temperature #1 reading. And since you were waiting for somebody with a similar system I thought I'd post:
+- ASUS P8Z68-V LX (/mainboard)
| | +- Temperature #1 : 78.5 26.5 86 (/lpc/nct6776f/temperature/1)
| | +- Temperature #2 : 56 50.5 59 (/lpc/nct6776f/temperature/2)
| | +- Temperature #3 : 32 30 32 (/lpc/nct6776f/temperature/3)
+- Intel Core i7-2600K (/intelcpu/0)
| +- CPU Core #1 : 41 38 65 (/intelcpu/0/temperature/0)
| +- CPU Core #2 : 41 38 68 (/intelcpu/0/temperature/1)
| +- CPU Core #3 : 40 37 65 (/intelcpu/0/temperature/2)
| +- CPU Core #4 : 35 31 58 (/intelcpu/0/temperature/3)
| +- CPU Package : 41 38 68 (/intelcpu/0/temperature/4)
+- NVIDIA GeForce GTX 570 (/nvidiagpu/0)
| +- GPU Core : 54 54 57 (/nvidiagpu/0/temperature/0)
Any ideas / opinions guys?
I have similar temperatures, no problems so far:
+- ASUS P8H67-M PRO (/mainboard)
| | +- CPU Core : 47.5 45.5 50 (/lpc/nct6776f/temperature/0)
| | +- Temperature #1 : 73.5 50.5 83 (/lpc/nct6776f/temperature/1)
| | +- Temperature #2 : 90.5 88 96 (/lpc/nct6776f/temperature/2)
| | +- Temperature #3 : 37 37 38 (/lpc/nct6776f/temperature/3)
+- Intel Core i5-2400 (/intelcpu/0)
| +- CPU Core #1 : 53 49 59 (/intelcpu/0/temperature/0)
| +- CPU Core #2 : 54 52 61 (/intelcpu/0/temperature/1)
| +- CPU Core #3 : 55 51 59 (/intelcpu/0/temperature/2)
| +- CPU Core #4 : 53 49 58 (/intelcpu/0/temperature/3)
| +- CPU Package : 58 55 61 (/intelcpu/0/temperature/4)
| +- GPU Core : 59 58 60 (/nvidiagpu/0/temperature/0)
I looked for the data sheet of the chip and the specifications say the operating temperature is T = 0°C to +70°C (well, we're 20 degrees over! :))
Storage temperature -55 to +150°C
Source: page 416 http://webshop.atlantikelektronik.de/Mailings/NCT6776F_NCT6776D_Datasheet_V1_2.pdf
