G GamingDonkey Reputable Nov 24, 2014 1 0 4,510 Nov 24, 2014 #1 So my PC tower top fan makes a weird high pitched noise when it is not spinning and this can get loud and I would like to know if i have to replace my fan my cpu fan seems ok same with the back on and the gpu is running fine it is only this one.
Solution Barney6262 Nov 24, 2014 What is the fan? A replacement would probably fix it, but I would get a different make of fan to avoid the same problem.
Barney6262 Honorable Oct 20, 2013 989 0 11,360 Nov 24, 2014 Solution #2 What is the fan? A replacement would probably fix it, but I would get a different make of fan to avoid the same problem. Upvote 0 Downvote Solution
