Pc turned on but no display and no hdd indicator light or power indicator light
dandyfosters
23
Hey so the title says it all
But i tried to unplug from power and push the power button 30 seconds, re plug the ram, re plug the gpu and got no luck
even though you re seated the ram and GPU, one of those could be faulty. just remove everything and plug in one ram (if u have 2/4 ram sticks) and turn it on to see if it shows something on the display or the indicator light starts functioning. if it works, keep on going by adding one by one until u spot the problem. if the first try with one ram didn't work, try another.
It also may not be any of those. it could be the power supply or that you need to reapply thermal paste
Nov 16, 2018
23
