Question PC turning on with fans spinning, red led on JFP, but no signal to the monitor - MSI MEG Z690I UNIFY
Apr 24, 2023
8
Hi all,
My PC suddenly shut down after 6 months of non-intensive use. I was not doing any software/hardware update before it append.
When I tried to turn it back on, I heard some "click" sound and saw that the PC was stuck in a loop of turning on and off iteratively.
Then it stopped and I'm now stuck with the fans spinning, a red led on the JFP1 mark, and no signal to the monitor.
I tried:
  • Clearing CMOS by pressing 5/10 sec with PC off, but nothing changed
  • Removing the RAM one after the other, but nothing changed
  • Removing the GPU and connecting the display directly to the motherboard, but nothing changed
  • Checked the monitor with another PC, it's not the issue
My configuration:
- CPU : Intel Core i7-12700K (3.2/5.2 GHz)
- CPU cooler : Noctua HN-U12A
- GPU: RTX 3080
- RAM : Kingston FURY Beast DDR5 64 GO (2*32)
- SSD : 1*Samsung 980 PRO MZ-V8P1T0BW M.2 PCIe 4.0 1T
- PSU : Corsair SF750 compte 80 plus platinium
- Fans : Noctua
- Case : Cooler Master NR200P Mini ITX
Thanks for you help, I spent all my money into that PC and I absolutely need it for my work :/
I tested the 24 pin connector from the PSU with a multimeter and everything is fine, I'm getting either 12v, +3,3v or -12v depending on the pin.
What should I ckeck next ?
You didn't test the supply with a load. Maybe motherboard suffered from infant mortality. Unplug the 3080 and try the onboard graphics for any life.
With 3080 unplugged and hdmi straight into the motherboard I’m not getting any signal on the monitor and still have the red led on JFP1 with all fans spinning (including those integrated on the motherboard).
Update : The motherboard was the issue, I changed it for a Z790I and everything is working now. Still don't know why it died suddenly.
hey i have a similar issue, was your motherboard on when it "died?"
my pc turns on i could see the lights on my motherboard and fans all work but no display to monitor keyboard or mouse. did you see your mobo lights on before you changed it for a new one
