PC turns off immediately after UPS switches from Battery backup to AC mains
Subhajitdas298
133
PC turns off after UPS switches from Battery backup to AC mains.
UPS: MicroTek MDP800+ (Dual battery 800VA)
Mains voltage (Rated): 230V
Mains voltage (Practical): 200V - 150V
What can be the problem? Need help immediately. Can not use my PC for long.
If it were me, I would pull the cover from the breaker box or service disconnect switch and measure voltage coming in directly from the utility meter to rule out loose connections downstream from there.
If you are in a 230V country and only get 150-200V, then it seems the logical thing to do would be filing a complaint with the power company for grossly unstable line voltage and hope it will do something about it.
Your other option would be to buy a line voltage regulator with adequate input range capability or possibly a double-conversion ("online") UPS that can accept low input voltage.
UPS switches to battery backup when mains power cuts off or Low voltage (around 150V-160V).
But no problem here.
Problem occurs when AC mains gets back, and UPS switches from battery backup mode to AC mains again.
By finding out why your line voltage is dropping so far below 230V and hopefully getting the power company to fix it if it is on their side of the service disconnect switch so your line voltage no longer dips that low.
Tolerances on line voltage are usually 10% not counting surges, swells, dips, brownouts, etc., so 200V "practical" should not be normal..
Ya, I reported my Problem many times to my power company, as this low voltage problem is not explicitly for me. This is the problem of our locality.
The government operated company (WBSEDCL) dosen't care for it.
As in India, nothing government based systems can not be good (being perfect is imaginary). Whereas private supply company CESC provides supply of 230V to 240V.
But my problem isn't the low voltage here. Is it?
My computer can directly run from an 150V outlet directly, but problem occurs with UPS, when switches back.
As mentioned earlier, the problem might be that your PSU does not have enough hold-up capacity to stay up when it gets switched from UPS to low line voltage.
Another thing you could consider doing is getting a better quality power supply but those appear to be a rare and expensive sight in India based on past posts by Indian members.
I am currently using VS550 and considering CX650 or RM650 or Seasonic 620 watt PSU in future when I will upgrade my PC for GTX 970.
But if necessary I will go now. But have to make sure, it will work. How can I do so?
Corsair VS 550
Thats a tier 3 PSU which is ok but not too good and may well have Taiwanese capacitors which are not as good as Japanese ones.
It would probably be worthwhile upgrading the PSU.
However if it is a fault in the UPS causing slow switching then a new PSU may not help.
Can you detect any delay as the UPS switches ?
It will be easier to check this by unplugging everything from the UPS and plugging in a single light bulb then unplug the UPS from the wall and plug it back in again to simulate a power cut.
If the light bulb goes off completely before coming back on then it may be a problem with the UPS if it only flickers then the UPS will be OK.
ATX12V Power Supply Design Guide Minimum Allowed Hold-Up Time: 16.0 ms
Corsair CX600/CX600M: 6.8 ms
Corsair CS650M: 11.6 ms
Corsair RM650: 12.8 ms
Those three models don't even meet ATX12V specs.
Hold-Up time is not the only thing you need to worry about when upgrading the PSU. You also need to determine if the new PSU's APFC (Active Power Factor Correction) circuit will be compatible with the UPS it will be plugged into.
Where did you find the hold times?
In power supply reviews. ATX PSUs are presumed to follow the ATX spec and most manufacturers do not bother specifying it, so the only place where you are likely to get numbers for it is PSU reviews.
Hold-up times are based on the assumption the PSU had a long enough pulse of sufficient amplitude to charge the input cap to their nominal voltage before power gets pulled though.
Since your PSU has active PFC, it is also possible the PFC circuit is getting confused by the transition from UPS to weak AC line voltage.
Hold-up time is defined as the amount of time, usually measured in milliseconds, that a PSU can maintain output regulations as defined by the ATX spec without input power. Another way of saying it is the amount of time that the system can continue to run without shutting down or rebooting during a power interruption event.
Corsair CS650M, CX600M and RM650 can be seen here:
Hold-up times that are too low are a result of using APFC capacitors that are too low in capacitance value. This is usually the case with budget level PSU's because lower capacitance value capacitors cost less and shaving cost is the primary concern.
I just bought an AC Voltage Stabilizer, but same problem remains.
The voltage is now 210v to 220 v, which is good.
This information is good but, practical hold up varies with load, isn't it?
Any way suggest me where to find the listing of this.
Can you provide Hold up time for VS550 and Seasonic M12II 620
