[SOLVED] PC turns on for a milisecond then turns off and blue LED near restart button stays on
It could be the PSU is detecting a short and cutting right back off.
Disconnect all the drives. Remove the video card & use the integrated GPU outputs. Disconnect all the USB devices, even Keybd & mouse. Disconnect all fans but the CPU's.
Now see if it will boot up and at least get you into the bios.
Jul 8, 2019
It could be the power supply. Try leaving only CPU and CPU cooler installed and start the board. See if the same.
My pc was actually using the red LED when it starts working and an orange LED in the MB if it receives power from the PSU but as seen in the video, it only lights up the blue LED and it was actually my first time to encounter it
popatim
