pc unusable help
aliwali0203
17
hello, i was changing my resolutions on my desktop and when i changed it too 1600x900 my screen went blank and there is just a blue box with white text inside it floating around my screen saying input not supported, so i tried to restart my pc with a restart button on my case trying to put it in safe mode by spamming F8 in the start up, it started booting the safe mode feature but when it says "select keyboard layout", i go to move my mouse to click on US but it doesnt let me move my mouse. my pc is basically un usable please help me!! thanks
hm. alright. well my suggestion is to either hook it to a monitor that can do 1600x900(any modern 1080 monitor should do), or get a keyboard and mouse that doesnt need a startup process so you can work with them inside safe mode.
um to split hairs, if it helps, you say your mouse doesnt work. is your keyboard working in safe mode? you could use tab, arrows, and enter to navigate menus. its slower, but it will work if the keyboard is working.
first, you should have just waited. when you change resolutions, it will ask if you want to keep it, and after like 30 seconds of you not clicking, change back to what it was.
have you tried not booting in to safe mode? it sounds like your mouse and keyboard might require some kind of startup process that is disabled in safe mode(which is what safe mode does).
i tried waiting 30 secs but it didnt work or maybe i close the window from random clicking i dont know and yes i have tried not booting in safe mode but i said that my screen is black because the input is not supported
