Pc upgrade help..
kingryx
19
Now i have this setup:
(i only play cs:go)
Core i5 2500k 3.3ghz (not o.c)
memory 8gb sniper
coolermaster 212 evo
evga gtx 650 ti 2gb
mother asus p8h67m-pro
Monitor samsung 75hz
power supply 700 watts
is better upgrade to 4ta gen or 5ta gen? or buy asrock z77 extreme4 and O.C core i5 to 4.0ghz?
i would wait for the newer 1060/1060 ti gpu and the newer amd gpu then buy one that not to pricey. i would then open a saving account and put some money into it for a newer build. when you have the funds look at skylake or it replacement that going to come out in 12-18 months. your gpu right now is holding you back in games. with newer games going to directx 12 your card does not support the newer directx versions.
