Pc Upgrade, Help!
Magikdude34
Commendable
Dec 13, 2016
For $500 there's a considerable amount you can upgrade...
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($26.88 @ OutletPC)
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-1866 Memory ($97.99 @ Newegg)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive ($44.99 @ B&H)
Video Card: MSI GeForce GTX 1060 6GB 6GB GT OCV1 Video Card ($244.49 @ SuperBiiz)
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply ($74.99 @ Newegg)
Total: $489.34
Generated by...
I'm not the biggest AMD guy, but I hear that FX-9000 series are pretty much the same. The most you can do is upgrade the GPU and probably the RAM. It's a shame they don't mention the PSU.
If you ahve $500, why not sell that thing and use the extra money and build a decent computer with a decent upgrade path?
EDIT: Just seen where it said power supply 400w. However, that is not enough to do much of anything.
Total: $489.34
Generated by PCPartPicker 2016-12-13 15:56 EST-0500
-CPU Cooler to overclock that 8320.
-Increased RAM.
-SSD for OS.
-GTX 1060 6gb for GPU upgrade.
-Much better quality PSU for GPU upgrade and CPU overclock.
The only thing you need to do is verify the case can house this cooler, GPU & PSU.
***I would actually hold off on upgrading RAM as 8gb is still plenty. You'll want to upgrade parts which then you can pair with a newer CPU/MB/RAM (DDR4) when its time to upgrade those. By the time your ready for a CPU upgrade Kaby-Lake (Intel) & AMD Zen (AM4) should be released and should offer a significant performance increase over that FX.***
