PC Upgrade help!!!
stefanaras1111
73
Hello i have a pc about 5 years now and it is finally start to have trouble playing the new games..
the specs
CPU: Intel Core i5 3570K @ 3.40GHz
GPU: 2047MB NVIDIA GeForce GTX 660 (Gigabyte)
MOTHERBOARD: Gigabyte Technology Co. Ltd. H77-D3H
RAM : 8,00GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
POWER: Corsair TX850M
what do you think i should upgrade first and maybe can i start upgrading my gpu with a gtx 1050 with these specs?? will my pc can handle it?
gpu first the 660 is long in the tooth
get a gtx 1050 ti minimum
gtx 1060 6gb would be ideal
you dont need to change anything else, well a SSD if you dont have one
so an gtx 1050 2gb would be a bad option and i should wait some time and raise money to go for a gtx 1050 ti ?? cause for sure i cant afford an gtx 1060 6 gb
1050 is too close to a 660, more of a side grade
you want a gtx 1050 ti at least to notice an upgrade
too bad the rx 470's are so overpriced now
this should help you
http://www.tomshardware.com/reviews/gpu-hierarchy,4388.html
you want at least three tiers difference to really notice an improvement
maybe you can find a gtx 770 4gb or 280x or 380x for a good price?
look at local listings where you live, might even dfind something good like a gtx 970, or r9 290x for a good price
you have a GREAT power supply, those older more power hungry cards are no issue for you
Will if i get an ssd cause i dont have one i have only a 2TB hhd feel a difference about gaming performance cause in some games i have slow load of the terrain...and is it hard to install??
