Question PC Upgrade Need Advice Pls!!!
Dec 6, 2024
4
Hey!
I am currently been trying to run Ark Survival Ascended but have hit the "obvious" road bump in the form of a lot of lag issue and generally completely unplayable. So I think its about time my PC got a bit of an upgrade.
My current Build is;
CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz 3.40 GHz
Motherboard: Asus Strix B250H GAMING
Memory: G Skill 8GB x 2
Corsair 8GB x 2
Video Card: MSI GeForce RTX 4060 VENTUS 2X BLACK 8G OC Gaming Graphics Card - 8GB GDDR6X, PCI Express Gen 4, 128-bit, 3x DP v 1.4a, HDMI 2.1a
Power Supply: 450W Corsair VS
Approximate Purchase Date: ASAP
Budget Range: All in (purchase and shipping) £500 - £750
System Usage from Most to Least Important: Gaming - Watching Youtube/Movies - General life work
Are you buying a monitor: No
Parts to Upgrade: CPU, Motherboard, Ram, PSU
Do you need to buy OS: No
Preferred Website(s) for Parts: Whichever gives the cheapest option while also being a safe place to purchase from
Parts Preferences: no real preference just as long as its all compatible and works like a Gem
Overclocking: No
SLI or Crossfire: Maybe
Your Monitor Resolution: 1920x1080
Additional Comments: Tend to mainly play Ark Survival Evolved but want to play the new Ascended version and currently its unplayable with my specs
And Most Importantly, Why Are You Upgrading: Current System needs to get up with the times of next gen gaming!
Have ample SSD drives and case is mid tower so big enough I would think. Also have enough cooling fans.
Any help from experts would be greatly appreciated. Currently unsure of a budget but would like to mainly know which parts need the upgrade and what potentially cheapest options they could be!
Many thanks in advance
Please stylize your thread with info asked of in this thread;
and the community can chime in with suggestions. You will need to include your location, your budget(with an amount) and your preferred site for purchase. Is your upgrade going to be solely for playing Ark Survival Ascended?
Off the bat, that PSU is something I wouldn't keep. You have 2 sets of ram kits from two different brands. Mind sharing a link to both of them? Out of curiosity, what GPU were you on prior to the RTX4060? Please add the make and model of your case as well.
Hey, Thanks for the speedy reply. Apologies for posting in the wrong format. I will amend it as we speak. Mainly Ark Ascended but potential future games
Currently I am struggling in finding the links for the ram. I only know that it is 2 8GB GSkill Ripjaws DDR3 and 2 8GB Corsair Vengeance DDR3. Previous GPU was GTX1060 .... Old XD
The Case again I am not sure and am struggling to find it as it came from PC Specialist but this is around 7 years ago!!!
Hi logainofhades. Thanks for your reply.
I do not live near a Micro Center. I should have mentioned I am in the UK. And Budget is around £500 - £750 for the parts needed. Cheaper would be best obviously!
As you have DDR3, you will need ram too. I would consider AM5, so you have future upgrade options.
PCPartPicker Part List
CPU: AMD Ryzen 7 7700 3.6 GHz 8-Core Processor (£245.00 @ Amazon UK)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler (£35.00 @ Computer Orbit)
Motherboard: Gigabyte B650 GAMING X AX V2 ATX AM5 Motherboard (£144.97 @ Amazon UK)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (£94.81 @ Amazon UK)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (£84.98 @ Scan.co.uk)
Total: £604.76
Generated by PCPartPicker 2024-12-06 19:13 GMT+0000
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor (£98.99 @ Amazon UK)
CPU Cooler: *Thermalright Assassin Spirit V2 66.17 CFM CPU Cooler (£15.90 @ Amazon UK)
Motherboard: *MSI PRO B760-P WIFI DDR4 ATX LGA1700 Motherboard (£119.99 @ Amazon UK)
Memory: *Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory (£52.99 @ Amazon UK)
Power Supply: *MSI MAG A650GL 650 W 80+ Gold Certified Fully Modular ATX Power Supply (£63.49 @ Scan.co.uk)
Total: £351.36
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2024-12-06 22:03 GMT+0000
Reactions: John Chesterfield
I looked at the system requirements and you are below recommended for both CPU and GPU, which changes things.
https://www.systemrequirementslab.com/cyri/requirements/ark-survival-ascended/22953
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor (£128.99 @ Amazon UK)
Motherboard: Gigabyte B550 GAMING X V2 ATX AM4 Motherboard (£85.00 @ Computer Orbit)
Memory: TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory (£52.44 @ NeoComputers)
Video Card: XFX Speedster SWFT 319 Radeon RX 6800 16 GB Video Card (£359.97 @ Ebuyer)
Total: £746.38
Generated by PCPartPicker 2024-12-06 19:18 GMT+0000
Personally, I do not believe you should buy a new graphics card before you get a new CPU and its corresponding platform. The below is what I would consider the minimum buy in for a modern platform. You could spend more on the CPU up to a 9700x but that be close to your max budget.
CPU: AMD Ryzen 5 8500G 4.1 GHz 6-Core Processor (£127.00 @ Amazon UK)
CPU Cooler: Thermalright Phantom Spirit SE 66.17 CFM CPU Cooler (£35.00 @ Computer Orbit)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard (£139.00 @ Computer Orbit)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (£105.47 @ Amazon UK)
Power Supply: MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply (£79.00 @ Computer Orbit)
Total: £485.47
Generated by PCPartPicker 2024-12-06 19:34 GMT+0000
Here is the same build with a 9700x:
CPU: AMD Ryzen 7 9700X 3.8 GHz 8-Core Processor (£304.99 @ Amazon UK)
Total: £663.46
Generated by PCPartPicker 2024-12-06 19:38 GMT+0000
Hey everyone, thanks a lot for all the help finding parts for me!
I have currently put together a list of parts I would like to buy but just wanted to double check with you peeps to see if its all compatible with each other.
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor (£189.97 @ Amazon UK)
CPU Cooler:
Thermalright Peerless Assassin 120 SE ARGB (£39.90 @ Amazon UK)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard (£144.99 @ Amazon UK)
Memory: CORSAIR VENGEANCE DDR5 32GB (2x16GB) DDR5 6000MHz CL36 (£91.33 @ Amazon UK)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply (£94.99 @ Amazon UK)
Storage: Crucial P3 Plus SSD 2TB M.2 NVMe PCIe Gen4 Internal SSD, Up to 5000MB/s (£99.99 @ Amazon UK)
Many Thanks in advance!
CPU Cooler:
With your choices above I would make these slight changes for various reasons. The Phantom Spirit is an even better version of the same CPU cooler and slightly cheaper. No change to the motherboard, PSU, and the CPU is fine. Change the RAM over to the G Skill Flare kit because it has an EXPO profile specifically made for AMD CPUs so you will experience guaranteed compatibility out of the box. I have heard that the Corsair vengeance kits have been having issues on occasion with AMD CPUs. The Western Digital Black SN770 is about the same price as the Crucial P3 Plus but a bit faster. If you need additional fans for the case I highly recommend the Arctic Freezer P12s in all sizes.
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor (£185.99 @ CCL Computers)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (£108.75 @ Amazon UK)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£104.99 @ AWD-IT)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply (£94.95 @ AWD-IT)
Total: £668.68
Generated by PCPartPicker 2024-12-08 07:52 GMT+0000
Hey @helper800 thanks a bunch for all the help you have been on finding parts for my computer!
All parts have currently been ordered which I am rather excited for them to arrive so I can get it all installed and start playing ark survival ascended and many more difficult to run games!
Many Thanks Again!
Reactions: helper800
