I was overclocking my FX 8350 and all was well until I changed the clock speeds of NB and HT link. I changed NB to 2600mhz and HT 2400mhz, saved, and then I heard a click as my PC turned off for good. I had the Vcore at 1.4V and CPU/NB at 1.2V-1.3V, somewhere between there.
I have tried leaving the CMOS battery out, I have tried using the jumper, nothing happens.
When I try booting, the CPU fan turns on and the auxillary fan turns on, but for some reason my GPU fan starts for a moment and then stops. All other peripherals like the disc drive and the HDD appear to do their normal startup routine, but nothing is displayed. Please please help, thank you.
Update: I just turned on my PC and put on my headphones and let it run, and I heard the windows startup sound... It's just my GPU that has the fan start and then stop immediately. Could overclocking my CPU have fucked it up in any way?
Update #2: Maybe a better bet is that the integrated graphics are being used for some reason. I just plugged a VGA connection into the motherboard and booted into windows completely fine, but to no avail the GPU continues just to have its fans spin at the beginning of boot. When I overclocked, the click that happened was rather loud.
Final update: Reseating the card finally made it work, and I'm working on reinstalling the drivers to fix the problems that came with that. Thank you everyone for the help.
