Question Pc Will not go to sleep
Feb 12, 2019
Hi, So recently I did few tweaks to my PC such as changing the rams. And it seems that my PC isn't able to go to sleep even after I used the old rams. in my Bios I have checked that the C-State is set to Auto. My motherboard is an Asus Sabertooth Z170S. I have checked all the Power Option in Windows and turned off all the ones that prevented my PC from sleeping. I can't figure out what's the problem and what's preventing my PC to fully go to sleep. So what occurs is that my Monitor goes all black but I can hear in the background that my PC is still indeed running still and for some reason my fans and the noise gets even louder than while it is running. I am certainty no expert but is the PC running in Hibernation State? Would could be the cause of this?
Also I made sure to turn this off http://prntscr.com/mkc9fi
Last Wake and Requests bring nothing
http://prntscr.com/mkc9ni
Power Efficiency Diagnostics Report
Computer NameKIRIGAROU
Scan Time2019-02-12T06:07:51Z
Scan Duration60 seconds
System ManufacturerSystem manufacturer
System Product NameSystem Product Name
BIOS Date03/14/2018
BIOS Version3801
OS Build17134
Platform RolePlatformRoleDesktop
Plugged Intrue
Process Count243
Thread Count4147
Report GUID{a6c77a2e-7675-4d0f-9a74-2eea67934967}
Analysis Results
Errors
Power Policy😛ower Plan Personality is High Performance (Plugged In)
The current power plan personality is High Performance when the system is plugged in.
Power Policy😀isplay timeout disabled (Plugged In)
The display is not configured to turn off after a period of inactivity.
Power Policy:Sleep timeout is disabled (Plugged In)
The computer is not configured to automatically sleep after a period of inactivity.
Power Policy😀isk idle is disabled (Plugged In)
The disk is not configured to turn off after a period of disk inactivity.
Power Policy:USB Selective Suspend is disabled (Plugged In)
The current power policy has globally disabled USB selective suspend.
Power Policy😛CI Express ASPM is disabled (Plugged In)
The current power policy for PCI Express Active State Power Management (ASPM) is configured to Off.
USB Suspend:USB Device not Entering Selective Suspend
This device did not enter the USB Selective Suspend state. Processor power management may be prevented when this USB device is not in the Selective Suspend state. Note that this issue will not prevent the system from sleeping.
Device NameAsetek VI USB Device
Host Controller IDPCI\VEN_8086&DEV_A12F
Host Controller LocationPCI bus 0, device 20, function 0
Device IDUSB\VID_2433&PID_B200
Port Path11
Device NameUSB Composite Device
Device IDUSB\VID_045E&PID_0772
Port Path7
Device IDUSB\VID_046D&PID_C083
Port Path10
Device IDUSB\VID_046D&PID_C085
Port Path6
Device IDUSB\VID_0483&PID_5025
Port Path5
CPU Utilisation😛rocessor utilisation is high
The average processor utilisation during the trace was high. The system will consume less power when the average processor utilisation is very low. Review processor utilisation for individual processes to determine which applications and services contribute the most to total processor utilisation.
Average Utilisation (%)7.09
Platform Power Management Capabilities😛CI Express Active-State Power Management (ASPM) Disabled
PCI Express Active-State Power Management (ASPM) has been disabled due to a known incompatibility with the hardware in this computer.
Warnings
Platform Timer Resolution😛latform Timer Resolution
The default platform timer resolution is 15.6 ms (15625000 ns) and should be used whenever the system is idle. If the timer resolution is increased, processor power management technologies may not be effective. The timer resolution may be increased due to multimedia playback or graphical animations.
Current Timer Resolution (100 ns units)10000
Maximum Timer Period (100 ns units)156250
Platform Timer Resolution:Outstanding Timer Request
A program or service has requested a timer resolution smaller than the platform maximum timer resolution.
Requested Period10000
Requesting Process ID14124
Requesting Process Path\Device\HarddiskVolume14\Program Files (x86)\Google\Chrome\Application\chrome.exe
Requesting Process ID19212
Requesting Process ID5272
Requesting Process ID3732
Requesting Process Path\Device\HarddiskVolume14\Program Files (x86)\Netease\UU\uu_ball.exe
Requesting Process ID16176
Requesting Process Path\Device\HarddiskVolume14\Users\Nii-San\AppData\Roaming\GameRanger\GameRanger\GameRanger.exe
Requesting Process ID16164
Requesting Process ID15636
Requesting Process ID6644
Requesting Process Path\Device\HarddiskVolume14\Users\Nii-San\AppData\Local\Blitz\app-0.9.19\Blitz.exe
Requesting Process ID12372
Requesting Process Path\Device\HarddiskVolume14\Program Files (x86)\Battle.net\Battle.net.exe
Power Policy😀im timeout is long (Plugged In)
The display is configured to automatically dim after longer than 10 minutes.
Timeout (seconds)885
CPU Utilisation:Individual process with significant processor utilisation.
This process is responsible for a significant portion of the total processor utilisation recorded during the trace.
Process NameDiscord.exe
PID13408
Average Utilisation (%)0.71
ModuleAverage Module Utilisation (%)
\SystemRoot\system32\ntoskrnl.exe0.24
\Device\HarddiskVolume14\Users\Nii-San\AppData\Local\Discord\app-0.0.304\Discord.exe0.23
0.08
Process NameGnSy DotA Tool 3.14.exe
PID15244
Average Utilisation (%)0.42
\SystemRoot\system32\ntoskrnl.exe0.17
\SystemRoot\System32\win32kfull.sys0.06
\Device\HarddiskVolume14\Windows\SysWOW64\user32.dll0.04
Process Namewermgr.exe
PID10964
Average Utilisation (%)0.40
\SystemRoot\system32\ntoskrnl.exe0.25
\SystemRoot\System32\ntdll.dll0.05
\SystemRoot\System32\drivers\FLTMGR.SYS0.01
Process NameBlitz.exe
PID14376
Average Utilisation (%)0.38
\Device\HarddiskVolume14\Users\Nii-San\AppData\Local\Blitz\app-0.9.19\Blitz.exe0.25
\Device\HarddiskVolume14\Windows\SysWOW64\ntdll.dll0.06
\SystemRoot\system32\ntoskrnl.exe0.02
Process NameWmiPrvSE.exe
PID2664
Average Utilisation (%)0.34
\Device\HarddiskVolume14\Windows\System32\ntdll.dll0.03
\Device\HarddiskVolume14\Windows\System32\wbem\fastprox.dll0.03
Process Namechrome.exe
PID14124
Average Utilisation (%)0.32
\Device\HarddiskVolume14\Program Files (x86)\Google\Chrome\Application\72.0.3626.96\chrome_child.dll0.24
\Device\HarddiskVolume14\Windows\System32\ntdll.dll0.04
\SystemRoot\system32\ntoskrnl.exe0.03
Process NameCAM.Desktop.exe
PID13212
\SystemRoot\system32\ntoskrnl.exe0.09
\SystemRoot\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_4aa19ae78d94d8a3\nvlddmkm.sys0.05
\??\C:\WINDOWS\temp\cpuz148\cpuz148_x64.sys0.04
Process NameMBAMService.exe
PID4672
Average Utilisation (%)0.31
\SystemRoot\system32\ntoskrnl.exe0.16
\SystemRoot\System32\Drivers\Ntfs.sys0.02
PID6644
Average Utilisation (%)0.23
\Device\HarddiskVolume14\Users\Nii-San\AppData\Local\Blitz\app-0.9.19\Blitz.exe0.10
\SystemRoot\system32\ntoskrnl.exe0.06
\Device\HarddiskVolume14\Windows\SysWOW64\ntdll.dll0.01
Process NameBattle.net.exe
PID12372
Average Utilisation (%)0.22
\SystemRoot\system32\ntoskrnl.exe0.07
\Device\HarddiskVolume14\Program Files (x86)\Battle.net\Battle.net.10949\battle.net.dll0.02
\Device\HarddiskVolume14\Program Files (x86)\Battle.net\Battle.net.10949\Qt5Core.dll0.02
Information
Platform Timer Resolution:Timer Request Stack
The stack of modules responsible for the lowest platform timer setting in this process.
Calling Module Stack\Device\HarddiskVolume14\Windows\System32\ntdll.dll
\Device\HarddiskVolume14\Windows\System32\kernel32.dll
Calling Module Stack\Device\HarddiskVolume14\Windows\SysWOW64\ntdll.dll
\Device\HarddiskVolume14\Windows\SysWOW64\kernel32.dll
\Device\HarddiskVolume14\Program Files (x86)\Netease\UU\ngpush.dll
\Device\HarddiskVolume14\Windows\SysWOW64\winmm.dll
\Device\HarddiskVolume14\Program Files (x86)\Battle.net\Battle.net.10949\Qt5Widgets.dll
Power Policy:Active Power Plan
The current power plan in use
Plan NameCustom
Plan GUID{98f4d663-8f1b-422b-b915-24f57cd2ec68}
Power Policy😛ower Plan Personality (Plugged In)
The personality of the current power plan when the system is plugged in.
PersonalityHigh Performance
Power Policy:802.11 Radio Power Policy is Maximum Performance (Plugged In)
The current power policy for 802.11-compatible wireless network adapters is not configured to use low-power modes.
Power Policy:Video quality (Plugged In)
Enables Windows Media Player to optimise for quality or power savings when playing video.
Quality ModeOptimise for Video Quality
System Availability Requests:Analysis Success
Analysis was successful. No energy efficiency problems were found. No information was returned.
Battery:Analysis Success
Platform Power Management Capabilities:Supported Sleep States
Sleep states allow the computer to enter low-power modes after a period of inactivity. The S3 sleep state is the default sleep state for Windows platforms. The S3 sleep state consumes only enough power to preserve memory contents and allow the computer to resume working quickly. Very few platforms support the S1 or S2 Sleep states.
S1 Sleep Supportedfalse
S2 Sleep Supportedfalse
S3 Sleep Supportedtrue
S4 Sleep Supportedtrue
Platform Power Management Capabilities:Connected Standby Support
Connected standby allows the computer to enter a low-power mode in which it is always on and connected. If supported, connected standby is used instead of system sleep states.
Connected Standby Supportedfalse
Platform Power Management Capabilities😛rocessor Power Management Capabilities
Effective processor power management enables the computer to automatically balance performance and energy consumption.
Group0
Index0
Idle State Count1
Idle State TypeACPI Idle (C) States
Nominal Frequency (MHz)4008
Maximum Performance Percentage637
Lowest Performance Percentage40
Lowest Throttle Percentage2
Performance Controls TypeACPI Collaborative Processor Performance Control
Group0
Index1
Idle State Count1
Group0
Index2
Idle State Count1
Group0
Index3
Idle State Count1
Group0
Index4
Idle State Count1
Group0
Index5
Idle State Count1
Group0
Index6
Idle State Count1
Group0
Index7
Idle State Count1
Device Drivers:Analysis Success
Try this...
  1. Go to start menu and type "Edit Power Plan"
  2. Launch it and select "Restore default settings for this plan"
Hopefully that worked, if not, then i cant really help you out that much cause I have not seen or heard about this problem until now.
Try this...
The restore default settings is greyed out and also I used to lose internet connection to games while I was in sleep. Now it just doesn't go to sleep.
Ok, reboot your computer and then try to restore default again. If that does not work, go to cmd (as administrator) and use the following command: "sfc /scannow" and reboot after finished . Then see if the problem continues.
I checked the information you initially posted and it says your motherboard does not support S1 Standby mode, so that apparently is not the cause as I thought... but other settings may be in conflict... you apparently have a Custom power plan running in the Windows Power Savings, but it is doesn't appear to be appropriately configured.... the Power Efficiency Diagnostics Report lists quite a few settings errors and warnings... a line on it says:
"The computer is not configured to automatically sleep after a period of inactivity"...
another line says: "CPU Utilisation: processor utilization is high"
and another says: "CPU Utilization: Individual process with significant processor utilization".
The information is too extensive to fully and efficiently analyze, so I would suggest go back and use the default Windows Power Plan (Balanced), and also restore the BIOS to the Failproof default settings, and only use custom settings after you fully understand what you're doing. For that, you may want to download the motherboard's PDF user manual (mobo manufacturer's model page > Support > Downloads) to individually check what each Power Saving BIOS settings mean, which hardware devices should be enabled or disabled so they don't keep the system running or wake it up when it should be sleeping. And for the Windows Power Saving Options, read a related Guide/Tutorial
SABERTOOTH Z170 S User's manual (English)
https://www.asus.com/Motherboards/SABERTOOTH-Z170-S/HelpDesk_Manual/
Windows Guide - Windows 10 Optimizations and Troubleshooting.
http://avid.force.com/pkb/articles/en_US/Troubleshooting/Windows-10-Guide
Going to try that.
how old is the PSU in your pc? depending on the age it may not support the C state instruction sets that modern intel CPU's have for standby mode
The PSU is 2 years old
evga supernova 850 p2 platinum
ok so it seems that even after the Bios Reset. Nothing is changing so I'm assuming that removing the Cmos Battery out of my motherboard really fucked up my motherboard and it will never enter back to S3 Sleep State ever again? The default sleep mode in my Window Settings hasn't changed anything. I really loved that feature of Sleep and probably will try getting the Warranty replacement. If anyone has answers let me know or ran into the same problem. would be nice quite nice.
I tried contacting Asus Support and they've recommend me to go to BIOS -> Advanced -> APM Configuration -> ErP Ready -> Enabled (S4+S5) -> F10
And this so far hasn't done anything. Just clueless on what's the cause here. Could it be Bios Settings? Faulty Motherboard? or faulty power supply? I just doubt it's either one of those. Also Rams? Since I know The S3 State is supposed to Store data in my Rams when it enters sleep mode.
Update: Asus Told me to do another Cmos Reset again. And this time it was uncessful again. Now theirs only one thing I must make sure if it's either my Window Settings or my motherboard being unresponsive to the rams. I will have to test both. I will probably try doing a Clean Boot using the Windows 10 Media Creator USB to test the Sleep Mode. Otherwise, I will have to change my motherboard completely and this will take some time because I honestly want this Sleep feature to come back as I use it on a Daily Basis and Hibernate mode won't cut for me because it's about 5 second difference.
S4 is Hibernation and S5 is everything off... so that suggestion is useless. Only S3 should be Enabled. Download the user manual and go to Chapter 3 (Page 3-29) for Power Saving settings... information from page 3-27 may be related so those settings may need to be Enabled or Disabled for 3-29 settings to work.
In Windows > Control P:anel > Power Options; Disable the Hibrid Sleep, Hibernation and Wake Timers settings so they don't interfere with Sleep Mode (Sleep After minute # setting)
https://dlcdnets.asus.com/pub/ASUS/mb/LGA1151/SABERTOOTH_Z170_S/E10962_SABERTOOTH_Z170_S_UM_WEB.pdf
Yup tried all those settings, I think their is nothing I can do but maybe ask for Asus for an RMA
