PC will not POST after upgrading to dual core!
Maxrinus
27
Hey everyone, thanks for reading.
Recently I attemped to upgrade someone's computer, however, it did not work.
These are the pc's specs:
Motherboard: Micro-star MS-7325
Intel Celeron D 3.2 ghz
2814 mb RAM (probably ddr2)
ati radeon xpress 1250
I bought a secondhand intel E8500 and built it in, the computer went on and the fans were spinning, but no screen. Changing it back to the celeron D made it work again.
I also checked the compatibility with the motherboard and it should work fine, also the TDW is the same.
Is there something I'm missing?
I actually found a bios update, so I think this is the problem. however it will not update because the bios is write protected, is there anyway to unlock this motherboard?
Now that I think of it.. it is a pre-built pc from acer.. an aspire t671
I will. Thank you for your quick reply. It is kind of ridiculous that the offer a bios update on their website specifically for this model and then won't let you install it!
