Question PC will not turn on
Apr 1, 2019
11
(First time putting together a PC)
2 sticks of Samsung 8Gb DDR3 1600 ram
3.5 Ghz 4th Gen I7-4770K (I know I cannot overclock it)
Seagate Video 3.5 1TB internal Hard disk drive 3.5"https://www.ebay.com/itm/Seagate-Video-3-5-1TB-Internal-Hard-Disk-Drive-3-5-HDD-ST1000VM002/163625141646?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2648
ASUS B85M-E ATX DDR3 LGA 1150 SATA 6GB https://www.ebay.com/itm/ASUS-B85M-E-ATX-DDR3-LGA1150-SATA-6Gb-s-Motherboard/183665385597?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2648
Shark 500W Standard ATX 12V Computer Power Supply
Rosewill TYRFING ATX Mid tower pc case.
Asus GTX 1060 3GB Pheonix edition
Hi guys, so when I plug in the power supply the motherboard and GPU light up. There are 9 pins on the bottom left of the motherboard that are for "HHD_LED, PWR_LED, RESET, and PWR BTN, + and - included," However my Case only came with two cords labeled PWR SW, and HDD LED+ and HDD LED-. Oddly enough my power supply did not come with a wire that is supposed to plug into a GPU so I have to get a new one anyways. I have tried almost every combination of the two wires on the 9 pins just as an effort to get the PC to work before I decide if I need to replace more than just the power supply. The PC case also came with Two wires that fit three pins for the two fans on opposite sides of the case. The motherboard only had 4 pins labeled CHA_FAN 1 so I was left with only one fan.
Am I doing something wrong?
Any specific PSU's or motherboards I buy to replace my software?
Thanks guys.
Latest posts
