Question Pc won’t turn on help needed
Feb 5, 2021
5
My specs:
X570 master
Straight power 1000 w
RTF 3090 strix
3600 32 gb trident z
Cooling custom watercooling 240, 360 mm rad
My pc suddenly turned off
doesn’t turn on anymore
Fans flash and the RAM lightens up
No code from mb
I swapped the psu but still same problem
I used a oc on the components the time the shutdown happened
CPU 1,35 mv @ 4,45 ghz
Gpu ~470 w @ 2100 mhz
Oc profiles r stable and used for many hours
Temps were around 60 degrees
I think my mb died is there a ez way to confirm this ?
Thanks ^-^
My specs:
X570 master
RTF 3090 strix
No code from mb
CPU 1,35 mv @ 4,35 ghz
Thanks ^-^
Jezzus theres no need for thoughs volts at all at that clock speed what the what????? Alrught to start have you tried clearing the system bios?
To do this.
Pull the power from psu
Remove cmos battery from mobo
Well both are removed hold power button on tower for 30s x2s
After reseat the battery and power cord try rebooting system
To do this.
I tried it but still nothing changed
