While trying to check if my USB connections were firmly plugged into my PC I acidentaly hitted one of my USB devices on the MoBo connection side. I recall hearing a strange noise coming from the PC.
After that the computer wouldn't boot up. The GPU and Ethernet Interface LEDs lighted up, both the fans from the case and Processor worked fine, I could also hear the HDD working while I tried to turn it on, but none of the USB devices were receiving power (as I have gaming Mouse/Keyboard with LEDs they simply wouldn't light up), also tried plugging a small USB External Fan, but no power coming through it as well and no video feedback.
With little research I discovered that the problem could be USB related, so I started experimenting different combination of used ports, but with the same devices. Some worked, some didn't, the most strange part is that even the Case front panel USB ports affect the final result. Couldn't find out any pattern after about 30 minutes of experimenting with it.
My conclusion: Couldn't find out if it's a problem with my MoBo USB Interface or maybe one of the USB Devices on short circuit.
Any thoughts ?
Any thoughts ?
