Question PC won't post or boot. Dram red light is constantly on. RGB works but CPU fans won't spin. Does the RAM not work?
Jul 2, 2024
I have a 7700x, gigabyte b650 gaming x ax v2, g.skill flare x5 32gb 6000 cl32 ddr5, and a be quiet pure power 12 m 750w psu.
I don't have any other components installed because I just want to see if the PC works.
I returned the motherboard and got a new one. I replaced the CPU with a 7600x and it still doesn't work.
I have tried the RAM in every possible configuration and updated the bios.
Not sure what to do from here. I also got some insight from some friends and everything they tried didn't work.
I've also waited for over 10 mins for all the boots.
Is it possible that both ram sticks don't work?
This is the exact model: F5-6000J3238F16GX2-FX5
How are you cooling the processors?
Which slots are the rams populating on the motherboard?
Did you inspect the CPU's socket for any bent or broken pins?
