As the title says, pc won't post everytime I try to turn until I fiddle around with the components. The pc still works but it gets really annoying that I have to fiddle around with the components everytime I have to turn on the pc and sometimes waste an hour or two just to turn it on. When the pc didn't post I tried by taking out all the rams and the mobo speaker didn't beep at all. I also tried taking out the pcie cable for the gpu and the speaker mobo didn't beep as well. I tried by resetting the cmos and that didn't work as well. Strangely I can turn on the pc successfully by plugging of all the sata cable from the mobo or by plugging the hdmi cable to the mobo hdmi slot. Taking out the gpu also work but those 3 methods only work sometimes so its a bit of gamble. I thought that the problem lies within the mobo as I thought that the mobo is the main source of all this so I tried my bros mobo in my pc. When I press the power button it turns on and then restart itself but no problem after that. The problem only occurs when plug off the psu from electricity. I tried my mobo on my bros pc and it takes around 2 - 5 mins after pressing the power button to turn the pc on. So I concluded that either my mobo or psu is faulty but don't know which one that needs to be replaced...
The specs is:
- i5 4590 3.3ghz
- 14 GB of rams (8 & 4 GB)
- gtx 1070 Asus Strix
- Zaman zm600-gv 80+ bronze
- 240GB SanDisk ssd
- 1TB Western Blue HDD
If anyone knows the problem please help out...
The specs is:
- i5 4590 3.3ghz
- 240GB SanDisk ssd
