I really need help.. I don’t know much about computers but I just know something is really wrong. My pc shut off and went to sleep after I stopped using it for a few minutes, which is normal. Except when it was time I decided to use it again, my pc turned on but wouldn’t display after I waved my mouse. This happened a lot recently (except the pc wouldn’t turn on at all) so I brushed this off and decided to just wait a couple of minutes until my mouse started responding again. Didn’t work, so I disconnected and replugged the mouse usb. Didn’t work, so thought it was time for new batteries… also didn’t work. 30 minutes pass and I tried everything (apart from psu switch/unplugging). Nothing has worked..
First I tried just turning off my computer w/ a power button tap and nothing happened, so I disconnected all extra connections, un plugged and replugged display port, reset my monitor and still nothing. Then I tried doing a hard reset/shut down by holding the power button and that’s when I realized the button wasn’t working at all… I pressed the tiny reset button next to it as a last resort and even that doesn’t work. My pc is not responding to anything and I can’t see anything because it doesn’t want to display. I’m dreading to use the psu switch/ unplugging my pc but I truly don’t know what else to do… it won’t even go to sleep by itself and it’s been well over 30 minutes at this point
If I do end up having to use the psu switch, how much of a chance is there for it to be completely safe and leave my pc unharmed ? Is there any other way I could fix these issues without being able to see my screen? Thank you…
