I've just installed a Cooler Master Hyper 103 to replace my stock heat sink and fan and now my PC won't start. When I press the on button nothing happens at all. There is no light on motherboard.
My specs are:
Gigabyte Z87 D3HP motherboard
Intel i7 4770k @ 3.50ghz
16gb RAM (4x4gb sticks)
2GB 7200rpm hard disk
Nvidia GTX 980 ti
Cit 750w PSU
It worked fine before I installed the cooler master. The installation went without a hitch so I have no idea what's caused this. I carefully cleaned the old thermal paste off the CPU and applied new stuff before seating the heatsink.
As the cooler master requires a back plate to mount I had to take everything off the motherboard and unscrew it from the case in order to take it out and gain access to the back. Could moving the motherboard out of the case inadvertently damaged it?
I've looked at threads on similar topics and checked everything I've seen there-
Motherboard power is connected
12v CPU 4 pin power is connected
All lights for power button/hard disk/reset are connected in correct pins.
Anyone have an idea what could be wrong and how I can fix it?
My specs are:
Nvidia GTX 980 ti
Cit 750w PSU
