Question Pc won't turn on after plugging case fans in
Sep 29, 2023
5
I was building my first pc and I had everything in and I turned it on and it worked except the case fans didn't turn on (which are plugged into psu), so I plugged the 3 pin case fan connector to the motherboard fan controller and now the pc won't turn on. I have tried unplugging everything and stuff it won't turn on anymore. Did I just fry the motherboard? I didn't smell burning or hear static.
Sorry
Cpu: ryzen 5 5600
Mobo: pro 4 b550m asrock
Ram: T-force knighthawk 3200 16gb
SSD: WD Blue SN570 2TB
GPU: Speedster 6800
PSU: Msi A750GF
Did you unplug the cable the tried to power up the PC again?I hope? Maybe your cable installation is incorrect. double and triple check.
I have unplugged everything and retried I tried without the 3 pin in it still doesn’t do anything
Ok, so given my own recent experience with a Deepcool case, they like to mention having fans, but don't want to talk about what type of fans. I suspect these are Molex connector fans and may have had an RGB connection?
If you connected an RGB connector to a fan header that is likely to be bad news. I am not even sure you can connect them that way.
What does this mean, did I fry the motherboard, psu, or just the fan?
