PC won't turn on after power outage
katsuai
7
Hello all, as the title says my pc refuses to turn on at all after we had a few seconds of power outage this morning. It's a standard HP pavilion s3750t if that's any help. I don't know about any other specs but it's the standard factory ones except for the gpu which is Radeon HD 5450.
It worked fine the night before but now there's not even a light blinking. It's plugged in to a surge protector and it was asleep. Tried plugging it somewhere else but nada, and the other things plugged on the same strip works. I even tried a different power cord. Could it be a fried power supply?
katsuai,
afraid as if it is looking like your PSU is dead. I just looked on HP site for part, with no luck. Also looked at Spare Parts Warehouse - no PSU for that HP model in stock - looked at motherboard, which they did have - $373 (Yikes!). May be cheaper to buy a second hand PC to keep you going if you really need it.
Tree branch fell knocking out the power when I was on my computer. Power restored, and I tried to turn on my computer, and nothing. There was a green light on inside the case, but as stated, the computer would not come on. I turned on my son's computer which was not on during the power outage, and it booted right up. Searched around a bit, and I found this thread. I do have an Asus motherboard, so I tried what was suggested. The first suggestion, holding the power button in, did not work. So, I unplugged everything from the case, walked into the kitchen, opened it up, and disconnected the power cable from the PSU to the motherboard. I did not hear any popping, so I was concerned. Sealed back the case, brought back to the computer room, plugged in the power cable, pushed the power button, and the computer started to boot. This solution worked for me. Thank you very much, as this saved me a lot of headaches!
