PC Won't turn on when i put 2 of 6 pins required in my GPU
Glenn_37
22
I have a EVGA GeForce GTX 570 when I put it in my motherboard with no 2 of 6 pins yet... My pc boots but no display.. gpu fans working and all stuffs but no display.. 2nd if i put now the 2 of 6 pins my pc won't turn on when i press power button 1 sec it will just turn off.
I will try it with my other power supply. I will inform you thanks for the reply!
Turns out to be it's really on the GPU tried it with my friends psu's true rated ones. Still not working also in there pc still not.
That sucks. Well, at least keeping performance close to where it is now is easy. A 1050 Ti should perform slightly better and only go for about $150 even with the mining craze. Getting something on a comparable current level is insanely priced at the moment (1070 at about $500). Best of luck
Anyhow, Thanks for the reply m8 I'm getting a 1050 ti today.
To all viewers if u have the same problem on the gpu you should try testing it on different pc. Different motherboard Different PSU. If it still persists its in the gpu.
