Archived from groups: alt.comp.periphs.mainboard.soyo,alt.comp.hardware.pc-homebuilt,alt.comp.hardware (More info?)
I'm building a system using:
Soyo SY-KT600 Ultra Platinum Edition Motherboard
Athlon XP 2500+ Barton
PC2100 sticks of several sizes and makes
The CPU's FSB rating is 333 MHz. Does that mean I can also run it at
266 MHz so as to synchronize it with the PC2100 memory?
I know the memory is not well suited to the CPU, but I just want to run
everything according to spec, safe and sane, without much tweaking.
The BIOS offers these settings for "CPU Freqency Mode":
Auto, Manual, 100, 120, 133, 140, 150, 166, 200.
The FSB can be set from 100 to 255 in 1 MHz increments.
The DRAM clock can be 100, 133, 166, 200, or by SPD.
The CPU multiplier can be set from 5 to 17 using DIP switches.
Would it work to just set the CPU frequency and the FSB and the DRAM
clock to 133?
How should I set the multiplier?
clock to 133?
