Question PCB panel power connector issue on my be quiet! Dark Base Pro 900 Rev. 2 ?
UpjumpedNeophyte
Commendable
Mar 24, 2020
6
Hello. In my pc case there's a fan/RGB controller that I need to find a power cable for. Normally I wouldn't sweat it since the fans are hooked up to the motherboard and I have no RGB. Unfortunately the Qi charger hooks up to this controller, and it won't work unless the controller is powered by this missing cable. The plug has four little metal pins inside it, and be quiet! says that the cable itself should be a 5V, 1A, 5W Sata. I have NO idea where I'm supposed to find a cable like that. Any help in tracking it down would be very much appreciated. Thank you and have a good day.
