PCI-E 6 Pin Power Supply Problem.
AlexSmith96
245
I have newly bought MSI R7750 Power Edition. But the problem is ... My PSU doesn't have a PCI-E 6 pin power connector.
But I got a 6 pin Y-shaped power connector in my graphics card box.
My question is : "Where should I connect the 6 pin molex cable (that I got) in my PSU as I don't see any slot for it in my PSU externally as well as internally ? "
You connect the 6 pin Y-shaped power connector to your power supply's molex connectors. If your PSU is modular you will find a socket just for that and a cable. Heres a picture of the connector
If its a modular psu you can try looking to buy a molex power cable.
But if you cant find one then you will have to get a good replacement 350 to 400W PSU which will be suffix for the card.
Thanks
