Pci e lead slot for motherboard
IceBear1499
Commendable
Oct 15, 2016
19
I just got the z730 aorus ultra gaming motherboard and I can't find the slot that the wire from my graphics card goes into. Then only one I can see is for my cpu. Any help would be appreciated, thanks.
What GPU do you have? Typically GPUs don't have wires coming out of them. Most GPUs have a PCIe connection on the bottom of the card and you insert it into the PCIe connection on the motherboard. There are wires that plug into the GPU as these are usually 6 or 8 pin cables coming from the PSU.
Yeah that's what I'm on about where does the pcie connection lead from the you go onto the motherboard because currently I only see one 6 pin connection slot and that's for my cpu
