Archived from groups: rec.games.frp.dnd (
More info?)
On Sun, 10 Apr 2005 07:16:03 -0400, "Jeff Goslin" <autockr@comcast.net>
scribed into the ether:
>"Matt Frisch" <matuse73@yahoo.spam.me.not.com> wrote in message
>news:0hvh515dj3tio13j90mofpl80dkiecja65@4ax.com...
>> >The higher standard is as close to perfection as is humanly possible,
>> Even if it was, which it isn't, you don't even allow for the possibility
>> that anyone can live up to it. A self-fulfilling prophecy that I bet you
>> aren't even aware of.
>No, I'm fully aware of the self-fulfilling nature of the failure. The
>phrase "nobody's perfect" truly applies. When humans try to attain
>perfection in ANY way, they are ultimately doomed to failure, due to the
>necessary imperfections inherent to humanity.
Paladins are not expected to be even close to perfect, however. Better than
other people and perfection are hardly synonyms. In a universe where even
true emodiments of their religious precepts (Celestials and Infernals) can
violate those precepts, expecting paladins to surpass that is just silly.
>> > and yes, that pedastal is of my own making.
>> Why not just make things easier on yourself and ban the class outright?
>> Since you've decreed Paladins must adhere to Lawful Stupid and not Lawful
>> Good...and that nobody can ever be good enough, why go through the
>trouble?
>Honestly, from this point forward, given my experience with PC paladins set
>at 100% failure over several attempts, I fully intend to.
>There are other classes that have alignment restrictions, like rangers and
>druids, but NONE of the restrictions are so difficult to implement, from a
>role playing perspective in a fantasy adventuring game as the paladin's
>restrictions.
That's completely arbitrary. Neutrality is *FAR* easier to violate than
Lawful Good.
>> > In our campaign, the paladin's life
>> >is the quest for that higher standard, not simply recognizing that he has
>> >reached some arbitrarily higher standard than most and does what he needs
>to
>> >in order to remain there. It is about betterment in a general sense,
>about
>> >setting the standard higher and higher, not about simply meeting some set
>of
>> >standards that are fixed.
>> So you've turned Paladins into Buddhists...with swords?
>I suppose that is a valid comparison, from a certain perspective. I take it
>that you don't believe that paladins should strive to better themselves?
I think everyone should. I don't, however, think that everyone should be
punished for not making it. There has to be a comfort level where you do
not have to constantly keep working harder.
>FYI, NPC Paladins in my campaign are often local nobles, ex adventurers
>turned land owners, considered just, wise and benevolent leaders by the
>commoners.
A holy warrior who collects rent...
Further, putting it into that perspective, if these types of people don't
have the authority to judge and sentence to execution prisoners...who does?
>> >It's not a problem for the alignments of the people who did it. It was a
>> >problem for the LG paladin, who's player did not role play the situation
>> >well enough for me to stand by and idly let him do it and still be a
>> >paladin.
>> If the paladin gets stripped of his abilities, then that is the result of
>> an evil act, not a chaotic one. The players in your party are EVIL, and
>you
>> try and justify it through chaos...I guess because you have some need for
>> your party to not be the bad guys.
>Your assessment of the evilness of our group is based on a faulty
>interpretation of justifications. The CG justification for the torture was
>that the information was necessary for the common good.
Interrogation of prisoners for information is hardly a violation of even
the most lofty of LG standards. Being punched a few times does not
constitute torture, especially for those times, when real torture was a
significantly gory affair.
> The CG reason for
>the executions was simply justification(they attacked us, with premeditation
>in the form of an ambush, intending to kill us, they deserve to die)
Also a perfectly valid LG reason. Or a LE reason. or TN reason. You really
have to come up with a better reason to be taking paladinhood away.
