Question PD HUB related question
madoues
Hi,
Say I have a PD enabled Hub with 4 USB-C outs, with a PD enabled power supply plugged into it's power input.
Say a cellphone is plugged in one of the outputs and it is fast charging using the PD function.
The way I understand this is that the port now provides a higher voltage needed for fast charging, up to 20V!!
However, if I now connect an SSD to one of the other ports on this hub, is there any risk of damaging the SSD?
In other words, is the SSD's port voltage now the same as the one the cellphone is charging from?
This is not at all clear to me; if the power supply providing power to the hub has voltage cranked up to charge the cellpĥone,
wouldn't that power be applied to all four outs? Otherwise the other 3 ports would have to reduce this increased voltage for an SSD
to function properly, or any other device not able to distinguish the PD function from an ordinary USB 5V voltage.
Sincerely,
Dan
You might want to share a link to this hub you speak of.
If the hub's design isn't shady/compromised, then no you won't be able to fry a data drive hooked to the hub. Some hubs tend to have specific ports that output power and are not meant for data transfer.
Subject to Lutfij's wise caution above, "If the hub's design isn't shady/compromised" you should have no problem. Any such Hub should manage the Voltage for each port separately according to what is connected there. In addition, consider this. Many Hubs have some ports specified as "Charging Ports". Charging connected high-power devices like a phone is actually a completely different function from data transfers that happens to use a USB connector system. In MOST cases (but not all) such Hub ports are ONLY for charging, and cannot do any data movement. Check the specs and manual for your Hub for this detail. Any Charging Port DOES have its own management of output Voltage that negotiates with the connected device to provide the right charging power. Such a port should never output power to a data device that exceeds the device's needs.
Thanks for your replies.
This is a bit what I suspected. IOW, one should be careful when buying these new Hubs,
and get all of the needed related information before.
Dan
Re:
"....one should be careful when buying these.... X."
Where X equals anything......
Agree.
Search for and read "X" product documentation: User Guides/Manuals, reviews,FAQs, etc..
Just a few minutes of extra, early effort may save many minutes of problems.
