I came back to my room earlier this evening just in time to see my PC oddly shut down right in front of me. I hit the power button turn it back on and nothing happened. I checked all the cables from the motherboard to my PSU but nothing turned it on. I tested the PSU and the fan came on just fine with the paperclip test. Everything seems to be plugged in just fine connecting the PSU to the motherboard and the other components attached to the motherboard (USBs and such). The odd thing is that the light on my keyboard, mouse, and blutooth dongle all have SOLID LIGHTS as if the power is on. While performing the PSU test with the hard drive plugged into it, the hard drive gets power as well. So I'm at a loss on how to turn this thing back on. I've disconnected the video card, pulled out the ram, tried it with one stick of ram in (closest to the CPU), and pulling out the CMOS battery. I just find the whole thing odd because my peripherals are all getting power though they would never light up like this if my system was turned off. I also tried to turn on the computer with a screwdriver where the power button plugs in, but that did nothing.
I'm not ruling out the PSU being bad but unfortunately I have no other PSU to test. I'm no expert but I've used these forums in the past to fix problems, and have gone through several threads, however I didn't find anything similar to this issue where everything is lighting up. Also, I have no power indicator on my motherboard. I would have noticed it when I was having issues with my last video card. I suspect that it's a motherboard issue because the CPU fan does not seem to be getting power, but that's just a guess
Relevent specs
Motherboard ipm17-dd rev 1.04 ODENSE
Intel Core i5-6400
DDR3-1600 PC3-12800 MB/s
Ultra LSP650 650-Watt Power Supply
Relevent specs
Intel Core i5-6400
