Question Phanteks Enthoo 719 fan hub and fans arrangement ?
Eamonn100
361
11
4,695
My Phanteks Enthoo 719 has a fan hub.
View: https://imgur.com/a/AKwfuCP
I would like to use it up first before using up the fan slots on the Motherboard. (If that is good practice).
Outtake Fans.
Basically, I will have 3... 140mm fans on the top of the PC... and 1... 140mm fan on the back close to the CPU fan.
Intake Fans.
I will have 3... 140mm fans on the front face, with 1... 120mm fan and 2... 140mm fans on the bottom of the case.
On this hub, how many fans can actually go through it. Is it safe and proper practice to use splitters from each plug slot for each sets of fans.
Ie... One hub slot for the top 3 fans. One hub slot for the front 3 fans. One hub slop for the bottom 3 and one for the 1 fan at the back? What would folks sugest?
I agree fully with Lutfij above. ASSUMING that you are using only 4-pin fans, use only the four 4-pin output headers for your fans. (Use the 3-pin headers only for 3-pin fans.) I recommend that you configure the mobo SYS_FAN or CHA_FAN header you use to feed this Hub board to use the newer PWM Mode, and not the older Voltage or DC Mode, and not any Automatic Mode option.
You have not specified exactly which fans you are using, so we cannot check their exact power specs. However, it is RARE for any such fan to consume over 0.25 A current, so even 10 fans in total will not exceed the 4.0 A limit of the Hub. Likewise, although the manual does NOT give this spec, it is common that the headers on the Hub EACH have a limit of 1.0 A, and three fans per header is still no problem.
Question: you have not said anything about your CPU cooler system. IF you are using a liquid-cooled system with a rad and fans, are those fans included in this total of ten? This is important because any fans involved in cooling the CPU chip should NOT be connected to this Hub. Such fans need to be controlled by a mobo fan header that uses a temperature sensor inside the CPU chip, and that is NOT any SYS_FAN or CHA_FAN header. Such fans need a different power and control connection.
Apologies... theses are my fans... Noctua industrialPPC NF-F12 iPPC-2000/3000 PWM IP67 120/140mm Fan
and my cooler... Noctua NH-D15 Chromax Black CPU Cooler + NA-HC4 Chromax Black
Reactions: 35below0
Thanks for the details, because the fans you plan are NOT "typical" - they are high-performance fans with higher max current consumptions than the common types. From their web pages, the max current use of each model is:
Noctua industrialPPC NF-F12 iPPC-2000 PWM 0.10 A
Noctua industrialPPC NF-F12 iPPC-3000 PWM 0.30 A
Noctua industrialPPC NF-F14 iPPC-2000 PWM 0.18 A
Noctua industrialPPC NF-F14 iPPC-3000 PWM 0.55 A
Noctua NH-D15 Chromax Black with 2x Noctua NF-A15 HS-PWM chromax.black fans: 0.13 A per fan = 0.26 A for the pair
NA-HC4 Chromax Black are just covers for the fans.
Now there are TWO parts of this where YOU need to do some calculations.
FIRST separate your fans according to WHERE they are used. The CPU cooler and its two fans MUST be connected to the CPU_FAN header of your mobo. That is the only header that will use the correct temperature sensor inside the CPU chip to guide it AND provide careful monitoring of the speed signal of ONE of those fans to detect possible fan FAILURE. So these two fans should NOT be connected to that general fan Hub board. Now the CPU_FAN header can supply power to all fans connected up to 1.0 A max current. You can see above that the two can consume up to 0.26 A, so no problem there.
NEXT address the CASE Ventilation fans. You have listed four possible models - not clear whether you plan to use all four types. The NUMBER of each type is not specified. As I said earlier, there are two limits you need to apply when connecting several of those fans to the Hub. For EACH output port of the Hub you cannot exceed 1.0 A max current for two or three fans connected to that header by a Splitter. Then also, for the TOTAL load on the entire Hub you cannot exceed 4.0 A max current. So you need to arrange all the case vent fans with Splitters on the four Hub output ports to adhere to those limits.
All fans generate a speed signal consisting of a series of pulses sent back to the host header for counting to display speed. But any header can deal with the speed signal sent back by only ONE fan. So all Hubs or Splitters will send to their host header the speed of ONE fan and ignore all the rest - you will never "see" those other speeds anywhere. This does NOT impact the ability to control theose fan speeds - in fact, that speed is NOT used in speed control. Control is based solely on a measured TEMPERATURE. But the header DOES use the speed signal to watch for NO speed signal indicating FAILURE. However, it can do that for ONLY the ONE signal it gets, so all other fans on a Hub or Splitter cannot be monitored for failure. YOU should look at all your fans from time to time to ensure they all still are working. On that Hub board, the only WHITE port is the one that WILL send one fans' speed signal back to the host header.
Oh, a final note. Noctua normally includes with most of their fans one or two "Low Noise Adapter" or "LNA" devices. These are small units that can be inserted into the fan cable connection to a mobo header or Hub port. The are useful ONLY when you are powering fans from some fixed-Voltage source (like a Molex power output from the PSU) and need a way to slow the fans down to less than max speed. Do NOT use these at all when you are powering AND controlling fans from a mobo header. They give you no advantage and have the real effect of limiting the maximum cooling you can achieve at high workloads.
Reactions: Eamonn100
Excellent stuff, thank you. I'm off to the races now.
Can the white socket on the hub be used like the rest?
Also, on one hub socket, I will be mixing a Noctua industrialPPC NF-F14 iPPC-2000 and a Noctua industrialPPC NF-F14 iPPC-3000. Is this ok, in reference to both having different maximum rpm and ampage?
Actually, the white Port #1 on that Hub board MUST be used for at least one fan. That is because it is the only one that sends its fan's speed back to the host mobo header. IF you leave that output empty, the mobo will report NO fan or a FAILED fan on that header.
Connecting those two different fans to one output port is just fine. The each will operate at different speeds and current consumptions, but that does NOT harm anything. They will receive and use identical power supply VOLTAGE from port Pin #2, and of PWM signal from port Pin #4, and both fans will be perfectly "happy" with that.
... and there are no problems running all 10 fans through the fan hub... (5 ports, 2 fans on each port)?
Will "AI Suite 3" Fan Expert still be able to read all fans, "Front", "Back", "Top" fans and I'll be able to control, set them up how I want them to perform?
Does the Mobo fan headers also have a 1.0A limit?
Just want to add that if the motherboard has a CPU_FAN header and a CPU_OPT header, you can use both headers. They both respond to the CPU temperature sensor.
And i second not using the LNAs. I did and they're more trouble than theyr'e worth.
Although Phanteks does not provide a current limit spec for EACH port, it is reasonable to assume it is 1.0 A max each port. NOTE that WHERE the fans are mounted has nothing to do with which output ports of the Hub you use. Splitting them up as two fans each on five ports makes sense. Note this also: some of us talked about the FOUR ports for 4-pin fans. But the WHITE Port #1 ALSO can work for 4-pin fans - it is a "universal" port. So that's the fifth port to use, and it MUST be used for speed reporting.
Be very careful of the largest fans you plan - the 140 mm 3000 RPM iPPC units. They can draw 0.55 A EACH, so do NOT put BOTH of them on one port of the Hub. But you can connect one of those plus one of another lower-current model together on one port.
You asked, "Will "AI Suite 3" Fan Expert still be able to read all fans, "Front", "Back", "Top" fans and I'll be able to control, set them up how I want them to perform?" NO. Re-read the second-last paragraph of my lengthy post on May 10/24. Any mobo fan header can deal with the speed signal sent back to it from only ONE fan. No matter how you connect several fans to one header, that header can only show you speed of ONE of the fans.
OP, your plan is to connect all 10 fans to ONE Hub, and that hub to ONE SYS_FAN header. So ONLY ONE of the fan(s?) connected to the White Port #1 of the Hub can have its speed reported to that header. You will never "see" the speeds of any of the others on the Hub. Even if you change and arrange THREE hubs to connect to all three SYS_FAN headers of your mobo, all that will give you is the speed of THREE fans out of your total of 10.
However, all this has VERY LITTLE impact on the ability of the mobo to control those fans. There IS this limiting factor. When you connect ALL your 10 fans through the Hub to ONE header, all those fans will receive the SAME speed control signal. Because they are different models the result will be each model runs at a slightly different speed from others and thus delivers slightly different air flows. All of them contribute to total air flow though the case, and your proposed arrangement of 6 intakes and 4 exhausts will give a reasonable balance. There really is no benefit to trying to customize the speed of any one group over others.
Of course, we are dealing ONLY with CASE vent fans. You plan to use a Noctua air cooler with two fans connected to the CPU_FAN header, so these do not impact air flow through the case. The WILL be controlled by that header according to CPU internal temperature, and independent of the case fans on a SYS_FAN header guided by a different temp sensor on the mobo.
MAYBE - info required is not published. But to help understand, more details.
In a complete HUB the unit most likely has only passive connecting wires (as traces on a printed circuit board) and no active chips. (The Phanteks hub board in your case is MORE complicated with active chips for conversion and control.) Most hubs are really suited only for use with 4-pin fans and PWM Mode control signals. (This Phanteks Hub is an exception.) Those original PWM Mode signals sent by a mobo fan header consists of:
Pin #1 - Black - Ground
Pin #2 - Yellow (sometimes Red) - +12 VDC constant
Pin #3 - Green (sometimes Yellow) - Speed pulse signal
Pin #4 - Blue - PWM signal
The speed signal generated in the fan motor and sent to the header on Pin #3 is a series of 5 VDC pulses, 2 per revolution. The header counts these to calculate fan speed. It does NOT control fan speed, and its value is not used by the mobo to control speed, but is used to monitor for fan failure. The PWM signal (pin #4) IS the control signal used by a chip in the motor to adjust its speed.
In a Hub, the main power supply (fixed +12 VDC, Pin #2) is NOT connected to the mobo header so it draws NO current from that source. Instead it is connected to a supply from the PSU as the main power source. The Ground (Pin #1) line also is connected to the PSU. The speed signal from ONE output port (usually Port #1) of the Hub is fed back to the mobo host header on Pin #3. The PWM signal from the host header is shared out to ALL Hub outputs on Pin #4 of each port, but the current drawn from that source is minimal and NOT subject to a max current limit.
The main consideration of power limits here is the power for the motor, involving the +12 VDC line and the Ground line. There is a limit imposed by the size of the conductor wires or traces in the Hub itself, but you almost never see that spec published. Some of us assume 1.0 A and the limit is likely higher than that, but not known. But what IS known is the limit imposed by the contacts in the connector to the outside power SOURCE. This is the limit for the TOTAL current for the entire Hub load, and NOT a limit on each individual output port. For a connection to the PSU via a SATA power output, that limit is 4.5 A. For a connection via a 4-pin Molex connector instead, that limit may be more like 10 A, BUT that also depends on how heavy the wires are in the cable from that connector to the Hub.
So to the specifics of the components you cite. The Hub board in the case from Phanteks uses a SATA power connection so the TOTAL load of the Hub is normally 4.5 A, but Phanteks has specified the limit of their Hub board to be less, at 4.0 A, probably because of the active elecroinic components of that Hub design. No spec for per-port limit, but typical spec for the chip that outputs power to a single fan is 1.0 A max. The EKWB-EK Cable unit is another type of Hub in appearance, but it does work the same way as common Hubs. Its website does not provide any limit specs. From its photos one of its "arms" gets the PWM control signal from a mobo header and returns to the header the speed signal from one fan. It makes NO other connection to the host header. All power for the fans is obtained by a 4-pin Molex connection to the PSU, so the CONTACTS of that connector are likely to support up to 10 A max curent. It IS likely that those wires would allow 1.0 A (maybe more) on each output, BUT the WIRES from the connector to all of the output connectors are NOT specified, so we cannot be sure about that over-all limit.
Your last query is a little unclear because you ask about "greater than 1.0A from each header". The name "header" refers to the MOBO fan header. When you use a HUB such as these devices the current limit of the mobo HEADER is not a problem because no current is drawn from it. BUT if you meant to ask whether you could draw more than 1.0 A from each OUTPUT PORT of a particular HUB, then that question depends on the HUB design as above.
In your case, careful arrangement of pairs of fans to FIVE ouput ports of the Phanteks hub board will get you all ten fans connected, powered and controlled safely without needing to create a load over 1.0 A on any one output.
Thanks, one last question...
if it was you, (or anyone else here with experience) would you plug your fans into the cases fan hub first, before using up the motherboards' fan slots.... or vise versa. Is it best practice to use up the motherboards' fan slots first and using the fan hub as a backup for other fans, etc at a later date?
Functionally there is no real difference UNLESS you anticipate needing more fans later. In your case with 10 already, I doubt that. There are four other reasons for using up mobo fan headers for SOME situations (and alternatives).
1. You have both 3-pin and 4-pin fans. The two fan types require different signal systems so they need to be connected to different headers each configured appropriately. You have only 4-pin fans. Moreover, that particular Hub you got can handle BOTH types of fan because of its unique design. So this does not apply to you.
2. Fan cables are too short to reach the Hub port or header you want to use. Then you can use a simple extension cable if you want to use exactly that source.
3. You want / need to set up different custom "fan curves" for certain fans for special requirements, so you need to use different headers for that. Few need this.
4. You want / need to "see" each fans speed, and cannot use a Hub or Splitter that does NOT report all fan speeds to mobo headers. This is almost never a NEED, more likely a personal preference. It can work ONLY if you have enough separate headers for all fans you want to monitor so closely.
The main advantage for using a Hub and plugging all fans into that is, for many, aesthetics - the routing of cables can be arranged very neatly to a central location, rather than to different spots scattered across the mobo. In your case with 10 fans all doing the same job, I'd probably go this way.
