detroitwillfall
Crashman :
JamesSneed :
"You know there are technical reasons why case manufacturers don't have USB 3.1 and it's the same reason MOST motherboard manufacturers don't offer an internal header with the spec: Cable length requirements mean that the case would need a repeater, and motherboard manufacturers worry about signal degradation between the header and port. That's why you're seeing USB 3.1 front-panel adapters with a built on controller, using either a PCIe slot or the PCI Express part of the SATA Express header."
No I didn't realize there were electrical limitations. Thanks I learned something new today. I had just assumed I would want at least one type-c connector for a new build this year as that should be more common over the life of the case. I guess I have some researching to do now on the various options.
should i get 1 meter LED strip or get 2 of them? i cant imagine needing more then 1
