The top of this case supports up to 360mm rad and of course 280mm radiator, which I have as an AiO Kraken X62. But I cannot actually utilize the top space where either the fans or the radiator would fit, because there is no way to fit the radiator in there with the tubes attached, and there is no way to screw the fans down from the top.
The top has a funny mounting bracket that slides out and slides back in once you have something in there, but it won't slide back in with tubes and a cooling block attached to the radiator. And if I put fans in the space and the radiator underneath I wouldn't be able to screw the fans down from the top.
Does this mean it will fit a radiator in that space in the top, just not with the hoses attached? So it excludes AiO's?
