I have a Gigabyte Z690 Aorous Master MB; the website says it has RGB LEDx2 and Digital Addressable LEDx2 but the manual shows a single D_LED1(3 pin, 5-Volt, I believe) and a single LED_C1(4 pin 12-Volt, I believe). I have a EZDIY-FAB GPU support bracket with 5V 3 Pin ARGB LED plugged into the 3 Pin header.
I wanted to get the Phanteks product in the title but am not sure if I can use it while using the support bracket...unless the two can be daisychained into the same header. Is this possible or am I missing something on the board?
