Phenom II x4 955 Overclock Help
NachoEmerson
40
I overclocked my cpu using amd overdrive inside of the CCC and I was wondering if this overclock is ok, im not to sure how to overclock a cpu, heres a pic in cpuz
First off lose AMD overdrive, uninstall it is a bunk program full of bugs....OC using the BIOS only...It is quite "easy" on that CPU.....BTW that OC is horrible voltage is way up ...Hell you could get it to 4.0 GHz at that voltage...
The X6 will allow for an NB frequency of 3000 MHz...The X4 is limited to 2800 MHz
HT is limited to 2600 and give no noticiable gain in performance that have seen I just keep it up there to make sure its at top speed...BTW Maximum voltage on the NB should never, ever exceed 1.35v....IMO 1.3v is maximum allowable "safe" voltage for the NB and HT
Thank you guys very much for the help, much appreciated! And I know I love this motherboard, it had every thing I needed and more. Never had a motherboard with dual x16 PCIe cappability. Looking forward to gettin another MSI HD 6850 in crossfire.
@Lowjack-- Thanks and I selected your first comment as the best just because you mentioned to get rid of AMD overdrive I was using it at the time and I now realize how sketchy that program overclocks and have a better understanding on OCing a CPU in the BIOS, thanks again for the help!
