Phenom II X4 955 SAFE OC settings/temp with stock HS/Fan
ricky86
21
Hi,
I just built a new system with an AMD Phenom II X4 955 Black Edition Processor.
I have it overclocked with 19x(16 is stock) multiplier and 1.4volts to the CPU and it is running at 3800Mhz. It runs anywhere from (doing basically nothing)39-46-55(fairly heavy load) Degrees Celsius.
This is the website I was using for information:
1.) http://blogs.amd.com/play/2009/04/22/overclocking-101-with-the-amd-phenom-ii-x4-955-black-edition-processor/
2.) http://www.extremeoverclocking.com/reviews/processors/AMD_Phenom_II_X4_955_15.html
I tried the above settings in AMD OverDrive and windows worked fine, so I set the same settings in the BIOS.
If these are safe temperatures, or it seems like a safe tune I will leave it as is.
Any help/info on overclocking anything more would be great!
- PCI-E Bus
- Memory timings
- Any other settings.
Here are my system specs:
- Logisys Area 51 Black ATX Window Case CS51WBK (Sucks, I know!)
- 2x 120mm Antec fan (1 intake bottom front-Medium speed/1 exhaust top rear-High speed)
- Removed side window fan since it got loud and placed a tube from the hole to the processor fan so the processor sucks from outside the case. Can post picture if requested.
- Antec Earthwatts 500
- AMD Phenom II X4 955 Black Edition
- Asus M4A785TD-V EVO
- Mushkin 4gb HP3-10666 2x2GB
- EVGA Geforce 9800 GT SuperClocked overclocked to 744/1799/1104 [Core/Shader/Memory] from 650/1625/950
- Samsung 2494HM @ 1920x1080px
I'm playing games(CS:S,COD:MW2,L4D2,Going to get Crysis soon, more similar) on my system, so I am pretty sure the graphics card is the bottle neck. But I have a 2 year extended warranty on it and the motherboard so I don't mind overclocking the hell out of both of them to increase performance in games.
Thanks in advance! :hello: :hello:
Hi temperature after doing my first overclock from 3.2GHz to 3.8GHz
amd overdrive listed temp at 31.5c-32c idle on all 4 cores and 47.5c-48c on all core in its 1hour stability test/OCCT also read 31c-32c idle,47c-48c on full load
when Intelburn test was used full load temp was 48.5c-49c full load on both the above
My system
Case----------------------------------- Coolermaster cosmos 1000
PSU------------------------------------ Coolermaster Real Power M1000
CPU------------------------------------ AMD phenom llx4 Black Edition 3.2GHz overclock to 3.8GHz (Cpu multiplier x20 ,HT ref.clock 190,CPU vid 1.500)
Motherboard------------------------- Asus M4A79T Deluxe
Graphics Card-------------------------Nvidia Geforce ENGTX260 TOP SP216
Cooling(CPU)--------------------------Corsair H50-1 Hydro series
Ram------------------------------------- Corsair Dominator 4Gb DDR3
Harddrive------------------------------ Western Digital Caviar Black 1TB
