Phenom II x6 1065T w/MSI NF750-G55 Mobo Voltage Help
FPSmadMEDIC
93
I am new to CPU and BIOS overclocking still, and have never really gone past the base overclock "meaning no need for voltage bumps and what not". My question is what should I do to my voltages after dropping proper multipliers to x8 to achieve proper NB and HT "@ 2000" and lowering ram down as well to achieve 1333 on desired OC, then since the multiplier is locked raising the FSB to 250 is what I want. I do know that with this cpu and air cooling a OC of 4.2+ is poss but I dont desire that out of this chip only a OC to 3.625Mhz. Coretemp says I have a avg of 20c on idle going as low as 17c. So what voltages in my BIOS do I need to change? I am getting a BSOD and I know its in my voltages that is causing this, all the parts are checked and working strong. Stock CPU Voltage is 1.275v
CPU OC Link: http://cpuboss.com/cpu/AMD-Phenom-II-X6-1065T
MY BIOS:
http://i1315.photobucket.com/albums/t599/WolfTekGaming/IMG_20131219_075259_zpsd00e314b.jpg
http://i1315.photobucket.com/albums/t599/WolfTekGaming/IMG_20131219_075319_zps8dba764d.jpg
BIOS CPU Cooling config screen: =135809411&filters[recent]=1&sort=1&o=0]http://s1315.photobucket.com/user/WolfTekGaming/media/IMG_20131219_075230_zpsc91d4d73.jpg.html?filters[user]=135809411&filters[recent]=1&sort=1&o=0
Current System:
CPU: Phenom II x6 1065T w/Cooler Master Hyper TX3 with 2 fans
RAM:16GB 1333 G.Skill RipJaws
GPU:XFX Radeon R7850 Ultra OC Edition 1GB w/ARCTIC Accelero TT II VGA Cooler 10% OC
MOBO:MSI NF750-G55
PSU:Inland 750E 80+ Bronze Cert
CASE:Antec 300 3x120mm intake fans 2 on front one on door over gpu, 1x120mm exhaust back, 1x140mm exhaust top
HDD's
OS HDD:Samsung 840 120GB SSD
2ndary HDD: 2x250GB WD in Raid on Jmicron Controller in a PCI 1x Slot
Storage HDD: 2x1.5TB Seagate Barracudas non Raid
So sorry that I havent gotten the articles up that I was talking about, life is throwing some curve balls atm and sadly I am losing my internet today so those will have to wait until I am back.
Whooot was able to save the internet! So I have been playing with this overclock a little and have discovered that bringing my multiplier up from 14x250=3500 to 14.5x250=3625 seems to bare no performance improvement which means I am at a wall with my current cooling solution being that the next step in the 1055 and 1075's is 4Ghz to see any real improvement. This overclock gives a 18% performance boost. I have the NB clocked at 10x250=2500 with 1.3v still and that seems very solid and the HT is at 8x250=2000 stock and have dropped the vcore from 1.3v to auto and these are the results after a 20min run to see temps. I still need to run a 1 to 2 hour to see if its stable on auto. Strangely though when I run it on auto it only grabs just over 1.3v on the vcore but when I run the stock settings with turbo core on the vcore grabs up to 1.36v and with turbo core off the vcore topps out at 1.28v
http://i1315.photobucket.com/albums/t599/WolfTekGaming/Untitled94_zps7b62a9e6.jpg
