Phone has sounds like a fax running for incoming calls
Blair
180
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I can phone out with no problems but when my PC(XP) is on but not on line I
find that incoming calls have this sound like a fax machine intermittently
and it stops after about a minute.
Very disconcerting to the caller and I have to tell them to hang on a minute
before it clears.
I feel it is something to do with my PC
Any ideas?
Blair
Hi Blair,
Control Panel/Printers and Faxes, right click the fax and choose properties.
On the devices tab, click properties, then go to the receive tab and uncheck
the box enabling it to receive faxes.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Blair" <pabm@brachd.fsnet.co.uk.invalid> wrote in message
news:uKVWmGQMFHA.1948@TK2MSFTNGP14.phx.gbl...
> minute
> before it clears.
> Any ideas?
> Blair
Hi Rick,
There is no fax listed under Printer and Fax. Also under accessories there
is no fax.
I may have misled you on the sound describing it as similar to a fax. This
sound is not continuous and stops after about a minute
Blair
"Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message
news:%23tfACySMFHA.568@TK2MSFTNGP09.phx.gbl...
> Hi Blair,
properties.
uncheck
> Best of Luck,
I
intermittently
> > minute
> > before it clears.
> > Any ideas?
> > Blair
Hi Blair,
If you suspect it is coming from the pc, try disconnecting it from the phone
line, then have someone call in. This will tell you real quick if it's the
problem or not. If it is, and you do not have the fax monitor installed,
then I would suspect that "wake on ring" is enabled in the system BIOS and
the system is trying to respond when someone rings in. Disabling this
feature may help.
Best of Luck,
news:e1%23SOycMFHA.3760@TK2MSFTNGP12.phx.gbl...
> Hi Rick,
> is no fax.
> Blair
>> Hi Blair,
> properties.
> uncheck
>> Best of Luck,
>> >line
> I
> intermittently
>> > minute
>> > before it clears.
>> > Any ideas?
>> > Blair
I received suggestion that I should use Start/Programs/Accessories/Fax/Fax
Console. Tool>Configure Fax.
> Uncheck 'Enable Receive'.
I also remembered that some time ago I used the fax facility but uninstalled
it. So I reinstalled it and carried out the uncheck 'Enable Receive'
and I no longer get the fax sound
Thanks for your help
Blair
news:ufZWzgfMFHA.2384@tk2msftngp13.phx.gbl...
> Hi Blair,
phone
> feature may help.
> Best of Luck,
> > Hi Rick,
there
> > is no fax.
This
> > Blair
> >> Hi Blair,
> > properties.
> > uncheck
> >> Best of Luck,
> >> >line
> > I
> > intermittently
> >> > minute
> >> > before it clears.
> >> > Any ideas?
> >> > Blair
I spoke too soon
The dreaded fax sound has returned so I deleted the whole fax facility by
using "services.msc"
Also disabled call waiting 1170
I tried to find "wake on ring" in the BIOS on my Dell Inspiron 1100 but
could find no reference to it.
What part of BIOS should I be looking at?
Blair
news:egYoXkiMFHA.244@tk2msftngp13.phx.gbl...
uninstalled
> Blair
> > Hi Blair,
> phone
the
and
> > feature may help.
> > Best of Luck,
> > > Hi Rick,
> there
> > > is no fax.
> This
> > > Blair
> > >> Hi Blair,
> > > properties.
> > > uncheck
> > >> Best of Luck,
> > >> >line
> > > I
> > > intermittently
a
> > >> > minute
> > >> > before it clears.
> > >> > Any ideas?
> > >> > Blair
I have at last solved the problem by downloading the latest modem driver.
Blair
> Hi Blair,
phone
> feature may help.
> Best of Luck,
> > Hi Rick,
there
> > is no fax.
This
> > Blair
> >> Hi Blair,
> > properties.
> > uncheck
> >> Best of Luck,
> >> >line
> > I
> > intermittently
> >> > minute
> >> > before it clears.
> >> > Any ideas?
> >> > Blair
