[SOLVED] Physical compatibility between parts
zachteran
7
So I’m building a pc for a friend, and I’ve made a parts list on pc part picker, something I’ve done many times. Most of the time pcpartpicker catches most compatibility issues and normally I would too but I’m unfamiliar with some of the parts in the build. (Here’s the link to the build):
https://pcpartpicker.com/user/Zachteran131/saved/MJkFt6
My question, other than overall compatibility, is if the cpu fan added into the build would be able to fit into the thermaltake case it’s being built in. If someone would be able to answer this eventually that would be amazing, I am in no rush!
It's an okay build.
I would go with this though, which will be much better.
CPU: Intel - Core i5-8400 2.8 GHz 6-Core Processor ($184.89 @ OutletPC)
Motherboard: MSI - B360-A PRO ATX LGA1151 Motherboard ($78.98 @ Newegg)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory ($114.99 @ Corsair)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive ($44.89 @ OutletPC)
Case: Thermaltake - Versa H21 ATX Mid Tower Case ($40.82 @ Amazon)
Power Supply: Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply ($42.98 @ Newegg)
Wireless Network Adapter: TP-Link - TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter ($14.50 @ Amazon)
Total: $522.05
Generated by PCPartPicker 2019-02-28 06:34 EST-0500
You don't need an aftermarket cooler the I5 8400 comes with a stock cooler which works perfectly for that CPU. Also, if you can fit this SSD into the budget for your OS Drive, it will make your system super snappy:
Storage: Kingston - A400 240 GB 2.5" Solid State Drive ($31.89 @ OutletPC)
Total: $31.89
Generated by PCPartPicker 2019-02-28 06:36 EST-0500
If you want the best bang for buck and future proof, you should be going AMD route.
Similar price but better.
Here's the equivalent AMD system:
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor ($164.99 @ Amazon)
Motherboard: MSI - B450 Gaming Plus ATX AM4 Motherboard ($104.99 @ B&H)
Total: $528.16
Generated by PCPartPicker 2019-02-28 08:50 EST-0500
Price is very close, but for gaming alone at 1080p the Intel system will win out on pure FPS. So 'better' is not wholly accurate.
With the above build, you get 6 more threads and future proofed until 2020.
Also change the ram to https://pcpartpicker.com/product/Cf98TW/gskill-memory-f43200c16d16gvkb (G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory )
There is practically zero difference between 3000/3200mhz DIMMS for Ryzen performance. Ryzen loves faster ram, yes. But the biggest bump in performance is going from 2400mhz up to 2933, after that the effects of faster ram taper off, and the difference between 3000 and 3200 is barely 1-2%. In addition the Corsair is CL15 timings, which makes up for the 200mhz difference as the Gskill are CL16.
You may not have clicked on the link, but its $10 cheaper that what you have selected
