Ah, yeah, no. I did a typo when I did that. I meant to say 5Gb/s, not 5GB/s. Thanks for pointing that out. I'll fix it. That's still 625MB/s though, not huge, but it would take maybe 2 minutes to fill the drive.
In any case, here's the item's listing at Canada Computers:
When I click on the specifications, it says:
Brand | Kingston |
Model | DTXM/64GBCR |
Flash Type | USB3.2 Flash Drive |
Capacity | 64GB |
Read Speed | 5Gbps |
Write Speed | 5Gbps |
It's currently $10CAD, but it was on for half-price when I bought them. I also bought four TeamGroup 128GB flash drives for $8 each but they're only 100MB/s (which I don't care about because I usually use these things as Windows image backups, and yes, it is 100MB, not Mb). Four 128GB and two 64GB USB3 flash drives cost me under $50CAD with tax included. You really can't go wrong, eh?
I
always read the specs of something that I'm buying before I buy it because the vast majority of the time, I don't buy by brand, I only buy by spec. The only time brand comes into the picture is when there's a brand that I want to avoid (and there's only three of those).
