PILE DRIVER FX 8350 NB AND HT LINK SPEED WHICH MUST BE HIGHER
adjboats
31
PLZ i have pile driver fx 8350, 890fxa-gd 70 and 16gb 1600mhz of ram. my bios state that north bridge must be greater or equal than HT link or FSB speed. but with this my NB cant move above 2200 even if i increase it to 2400 or 2600 in bios it still read it as 2200 on windows but my HT link speed or FSB frequency can increase to 2600 MHz sometime my NB and HT speed readings are the same even if my NB speed is at 2800 MHz whiles my HT link speed is at 2300 MHz. on windows both HT OR FSB SPEED AND NB SPEED READ AT 2300. I WANT TO KNOW WHICH ONE SHOULD BE HIGHER. AMD CUSTOMER SUPPORT SAID HT OR FSB SPEED SHOULD BE HIGHER THAN NB SPEED? IT'S TRUE! I WANT TO KNOW IF THERE'S A PROBLEM WITH THE MOBO OR CPU. I HAVE THE LATEST BIOS FROM MSI 1G1
Your IMC/NB speed should be higher than your HT Link speed. If you are worried in some fashion you may drop your HT Link multiplier.
The IMC/NB and HT Link speed are each a product of the system clock (or, *FSB*) --- as is your CPU speed. The stock system clock is 200MHz
CPU = 20 x 200MHz (turbo = 21x200MHz)
IMC/NB = 11 x 200Mhz
HT Link = 10 x 200MHz
