Hey guys what's the best way to approach this? I was trying to open the lever and themn I think my hand touched one on accident. I bought this on eBay this week what should I do? http://imgur.com/ugl4S5D
Yeah it absolutely looks like you're missing pins. You should see the same corresponding pin slots missing I think on the opposite side. Are there any bent pins under the tray?
This is a picture of my socket. Yes you can see the bent pin but you can see there's no missing pins from holes. This is a picture of an 1151 socket. Not sure what yours is.
Clear picture of an 1155 socket set. Regardless of the void in the middle the pins should be the same exact layout.
You're missing pins. Sorry to say but I really don't think you did that. I'd return that asap.
Ya I'm sure I didn't do this. all I did was take it out and coverd it with a towel and I tried to check the picture on eBay but too blurry..Thanks for the help anyways
Alright. Let us know what you do and what results it turns. There may be other people out there who have this issue. Just select whatever works for you as the best answer or the best idea that helps. If this doesn't help you we can continue to troubleshoot after fact or provide alternatives.
