[SOLVED] Planning on buying a PC but I don't know if I picked the right parts
questionsquestions
I'm not much of a tech person so I decided to customize one of Cyberpower's prebuilt PCs, the problem is that I don't know if what I chose is good or even compatible. I did a bit of research, but there are some things that go completely over my head. Any help would be very appreciated!
Operating System: Windows 10 Home (64-bit Edition)
4th of July Featured Promotions: None
Message: None
Gaming Chassis: CyberPowerPC ELUNA 242V Premium RGB Gaming Case Mid-Tower w/ Tempered Glass Window Panel + 3x ARGB Fans (Black Color)
Laser Engraving: None
Extra Case Fans: Default case fans
CPU: Intel® Core™ Processor i7-11700F 8/16 2.50GHz [Turbo 4.8GHz] 16MB Cache LGA1200 [w/o Integrated Graphic]
Freebie of Processor: None
Venom Boost Fast And Efficient Factory Overclocking: No Overclocking
CPU / Processor Cooling Fan: CyberpowerPC MasterLiquid Lite 240mm ARGB CPU Liquid Cooler with Dual Chamber Pump & Copper Cold Plate (Intel)
Coolant for Cyberpower Xtreme Hydro Water Cooling Kits: None
Motherboard: ASUS PRIME Z590-V ATX, ARGB, 1GbE LAN, 2 PCIe x16, 3 PCIe x1, 4 SATA3, 3x M.2 SATA/PCIe
Freebie of Motherboard: None
RAM / System Memory: 16GB (8GBx2) DDR4/3200MHz Dual Channel Memory (ADATA XPG Z1)
Video Card: [Extra 2 Weeks Lead Time] GeForce RTX™ 3060 12GB GDDR6 Video Card (Ampere) [VR Ready] (Single Card)
Video Capture Card: None
Power Supply: 750 Watts - Corsair RM Series RM750 80 PLUS GOLD Certified Fully Modular Ultra Quiet Power Supply
Primary Hard Drive: 240GB WD Green SSD + Seagate 2TB SATA III Hard Drive Combo (Combo Drive)
Secondary Hard Drive: None
External Storage: None
WiDi Router: None
Internal Wireless Network Card: None
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
Monitor: None
Cables: None
Speakers: None
Internal Network Card: Onboard Gigabit LAN Network
Keyboard: None
Mouse: CyberPowerPC Standard 4000 DPI with Weight System Optical Gaming Mouse
Mouse Pad: None
Headset: None
Microphone: None
Gaming Gear: None
Wireless Routers/Hubs: None
Video Camera: None
Power & Surge Protection: None
USB Hub & Port: Built-in USB Ports (Based on motherboard and case selection)
External Accessories: None
Windows 10 Recovery: None
Professional Wiring: None
Ultra Care Option: None
Warranty: STANDARD WARRANTY: 1 Year Parts WARRANTY
Service: 3 Years FREE Service Plan (INCLUDES LABOR AND LIFETIME TECHNICAL SUPPORT)
Message: None
CPU: Intel® Core™ Processor i7-11700F 8/16 2.50GHz [Turbo 4.8GHz] 16MB Cache LGA1200 [w/o Integrated Graphic]...
Hey there,
Whilst I don't necessarily advise people to purchase pre-builds, this is more custom.
With that said, it's a quality build, with very good parts. You can expect top gaming/productivity performance, whilst not going into the HEDT realms. The GPU is mid range, but very capable at 1080p and 1440p.
The CyberPower Cooler, is actually Coolermaster, so that's nothing to be concerned about.
I guess some will argue about the pricing. You could build for less no doubt, but getting it built and configured to work right out of the box is a plus. To you it might be worth the premium.
Message: None
WiDi Router: None
Monitor: None
Cables: None
Speakers: None
Keyboard: None
Mouse Pad: None
Headset: None
Microphone: None
Gaming Gear: None
Video Camera: None
You have a Z590 board and a locked cpu along with a liquid cooler. Also a 550w psu will power that 3060. The SSD is a bit small also. You could order the parts yourself and build it or pay a local PC shop to put it together after the parts arrive.
Something like this ...
https://www.newegg.com/black-phanteks-eclipse-p400a-atx-mid-tower/p/N82E16811854085
Phanteks Eclipse P400A $69.99
Exhaust fan for that case
https://www.amazon.com/Antec-120mm-Performance-Connector-Single/dp/B08PVL8FJJ/
Antec 120mm Case Fan $5.99
https://www.newegg.com/super-flower-leadex-iii-sf-550f14hg-550w/p/1HU-024C-00008
Super Flower Leadex III 550W 80+ Gold Modular Power Supply $79.99
https://www.newegg.com/p/N82E16813144396
MSI MAG B560M BAZOOKA $139.99
https://www.bestbuy.com/site/intel-...ked-desktop-processor/6452218.p?skuId=6452218
Intel Core i5-11400 $189.99
https://www.amazon.com/Gelid-Solutions-Phantom-Cooler-Case/dp/B076KYYSRW
Gelid Solutions Phantom CPU Cooler $36.99
https://www.amazon.com/Crucial-Ballistix-Desktop-Gaming-BL2K8G32C16U4B/dp/B083TRRT16/
Crucial Ballistix DDR4 3200MHz 16GB (8GBx2) CL16 $87.99
https://www.amazon.com/PNY-CS2130-Internal-Solid-State/dp/B0869B4Q66/
PNY CS2130 1TB M.2 PCIe NVMe Gen3 x4 Internal SSD $114.99
https://www.amazon.com/Microsoft-Windows-English-Flash-Drive/dp/B075RM5BHV/
Microsoft Windows 10 Home | USB Flash Drive $129.95
Total: $856
https://www.ebay.com/itm/124793339383
GIGABYTE AORUS GeForce RTX 3060 ELITE 12GB GDDR6 Graphics Card $750.00
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1311&_nkw=rtx+3060&_sacat=0
Review of that cpu. Look for Core i5 11400F + Opt on the benchmarks.
https://www.guru3d.com/articles-pages/intel-core-i5-11400f-processor-review,1.html
A better look at that board.
https://www.msi.com/Motherboard/MAG-B560M-BAZOOKA
A better look at that Case.
https://phanteks.com/Eclipse-P400A.html
