Play sound without launching media player
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsxp.customize (More info?)
How do I play a WAV file I have got in a folder *without* launching a media
player?
Most of the warning sounds XP uses do not need a media player to be
launched. How can I test my WAVs using the same method of playback?
| "Peter Davis" <nomail@privacy.net>
| Message news:9554A3FC05FFB5D4AM2@127.0.0.1
| launching a media player?
| to be launched. How can I test my WAVs using the same method
| of playback?
If, for example, the WAV is named:
e:\helpmeet.wav
Click Start, click Run, type the following command and click OK:
sndrec32.exe /embedding /play /close e:\helpmeet.wav
Thanks to the Scripting Expert "Torgeir Bakken (MVP)" for the
above command.
REFERENCE:
From: "Torgeir Bakken (MVP)" <Torgeir.Bakken-spam@hydro.com>
Newsgroups: microsoft.public.win2000.general
Subject: Re: Play sound in command prompt
Date: Sun, 23 Feb 2003 01:27:42 +0100
Message-ID: 3E58157D.33F1478F@hydro.com
> media player?
You can also open Control Panel/Sounds and Audio Devices/Sounds Tab. Select
any system event and click the Browse Button. Browse to the folder and
select the .wav file. Click the small Srrow button next to the Browse button
to play the file. You can make this file an option in the drop down list of
sounds by placing it in the C:\Windows\Media folder.
Regards,
Ronnie Vernon
Microsoft MVP
Windows Shell/User
Please reply to the newsgroup so all may benefit.
http://www.dts-l.org
http://www.mvps.org
>> of playback?
> Devices/Sounds Tab. Select any system event and click the
> Browse Button. Browse to the folder and select the .wav file.
> Click the small Srrow button next to the Browse button to play
> list of sounds by placing it in the C:\Windows\Media folder.
That is ingenious, thank you, but it's not quite what I want.
What I really want is to double click a WAV file and hear what it sounds
like.
>| to be launched. How can I test my WAVs using the same method of
>| playback?
> e:\helpmeet.wav
This seems quite promising.
What I would like to do is play the WAV file by double-clicking the file.
I used file associations and associated WAV with "sndrec32.exe". But when
I double click a WAV file then XP just launches sndrec32.exe. Then I need
to press 'Play' to actually hear the sound.
I don't really want the player to launch nor do I want to press anything.
How can I get the file association to include the parameters you gave me so
that I end up with:
Can anyone advise?
Windows Explorer
Tools
Folder Options
File Types
WAV
Advanced
New
- - -New File Type- - -
Action: Hear
Application: sndrec32.exe /embedding /Play "%L" /Close
[y] Use DDE
DDE Message:
DDE Application Not Running:
Topic: System
OK
Set Default
OK
Close
| >| playback?
| > e:\helpmeet.wav
| that I end up with:
| Can anyone advise?
Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsxp.customize,alt.comp.freeware (More info?)
"anonymouse" <anonymous@discussions.microsoft.com> wrote:
> Windows Explorer
> Tools
> Folder Options
> File Types
> WAV
> Advanced
> New
> Action: Hear
> [y] Use DDE
> DDE Message:
> Topic: System
> OK
> Set Default
> OK
> Close
I have been trying your method. Thwe firsth to get over is the lack of an
ADVANCED button on the window for the WAV file type. Hewever, when i press
restore default then my WMP8 takes over and the edit button is there.
I can overwrite the WMP8 info with the path to sndrec32.dll and now I can
add the parameters of /embedding and /play into the box which appears whe I
press ADVANCED. i edit the entry for PLAY. So far so good and wear
saynght same thing.
Now we differ. I keep action as "&Play" (no quotes). I enable DDE. My
application box entry is as follows:
C:\WINDOWS\Sndrec32.exe /embedding /play /close %1
anmd there is nothing in DDE Message, DDE application not running and in
the Topic box is the word "system".
All works very nicely.
BTW I installed player called "1by1" (or One By One if you orfere) which is
totally free and very small at 54KB. From http://www.mpesch3.de/. It
advantage is that it will play individual WAV files but through its odd
interface it will paly whole series of WAV files one after the other so you
can hear what they are like.
You will need to get some DLLs from WINAMP but that is easy enough even
though it's an unconventional step to take.
Hope this helps someone.
Peter
[groups widened to include freeware group whose website steered me to 1by1]
