Pleas help me with graphic cards.
Jun 25, 2018
39
Hello.
I have intel i5 6400 and i want the best graphic card for this cpu. I was looking for gtx 1050ti.
But i have one graphic card installed in computer ( nvida quadro p600) and I want to have 2 graphic cards in computer beacuse quadro is not good for games. Can i have 2 graphic cards in one computer? Which graphic card would you take with i5 6400?
Thanks for answers :)
What are you basing this on? There hasn't been any benchmarks yet to verify this. Not to mention that the 1060 6gb tend to cost more than the faster, cheaper RX 580
You can have two GPU’s in a machine. You would need cards that can operate in what’s called SLI (Nvidia) or Crossfire (AMD). Your motherboard would need to support this feature as well.
Secondly, using dual cards for an i5 6400 is not advisable. I would recommend one single card that has the juice to run your games at an acceptable level. I would suggest a GTX 1060 6GB, RX 570 or 580, or some other card within that range. A 1050ti would be fine as well.
thanks for answer.
would RX 570 work better than 1050ti?
So that means that I would have to uninstall quadro p600?
But it is expensive. Why is 1050ti no good?
some battlefield, call of duty. a lot of assassisn creed espesaly oddysey. and maybe some need for speed.
So 1050ti will be enough?
okey. which would you choose: 1. Gigabyte GeForce GTX 1060 WINDFORCE OC 6G
or 2. ASUS GeForce GTX 1060 6GB Dual-Fan
what oc means?
Is not gtx 1060 too much my cpu?
I will probably go with gtx 1060 6gb. But is that real that i can´t have in my comuter quadro p600 and this graphic card? Beacuse i would really love to have both graphic cards
Okey, but is not my cpu too weak for this graphic card?
Can I have gtx 1060 and quadro p600 in one computer?
How much power supply would i need?
