I'm gonna leave a YT link so you guys can see what my is my problem and if it can be solved.
Thank You.
View: https://www.youtube.com/watch?v=uwexTMYX_aU&feature=youtu.be
Thank You.
If you are using the same cable and have the latest PS update I think they updated to HDCP 2.2 which might not be compatible with the monitor.I don't know the model, but I do know this monitos used to work just fine before when the HDCP was enabled. let me search for the model
HERE IT IS
https://www.amazon.com/gp/product/B00M8E0K06/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
I don't know the model, but I do know this monitos used to work just fine before when the HDCP was enabled. let me search for the modelWhat's the monitor model?
Not all monitors support HDCP.
HERE IT IS
I think so, yeah.If you are using the same cable and have the latest PS update I think they updated to HDCP 2.2 which might not be compatible with the monitor.
Did this started happening after PS update?
HelloI think so, yeah.
